Ga door naar hoofdinhoud
Zoomer Meowzies Chest Senor Replacement
Wat je nodig hebt
  1. Zoomer Meowzies Chest Senor Replacement, Legs: stap 1, afbeelding 1 van 3 Zoomer Meowzies Chest Senor Replacement, Legs: stap 1, afbeelding 2 van 3 Zoomer Meowzies Chest Senor Replacement, Legs: stap 1, afbeelding 3 van 3
    • Using the Triangle driver remove the four 7.5 mm screws.
    • The two front screws are deeper than the two on the back legs which may cause difficulties. These can be reached by putting the bit in first then carefully putting the driver on slightly (not all the way)
  2. Zoomer Meowzies Chest Senor Replacement: stap 2, afbeelding 1 van 2 Zoomer Meowzies Chest Senor Replacement: stap 2, afbeelding 2 van 2
    • Turn the device so that the the device is on its side.
    • Hold the back and belly on the device and gently pull apart.
    • Pulling with too much force might damage a few cables inside, so caution is needed.
  3. Zoomer Meowzies Chest Senor Replacement: stap 3, afbeelding 1 van 3 Zoomer Meowzies Chest Senor Replacement: stap 3, afbeelding 2 van 3 Zoomer Meowzies Chest Senor Replacement: stap 3, afbeelding 3 van 3
    • With insides exposed, grab leg and gently pull up and away from the body to detach them. Repeat for all legs needed.
  4. Zoomer Meowzies Chest Senor Replacement, Chest Senor: stap 4, afbeelding 1 van 3 Zoomer Meowzies Chest Senor Replacement, Chest Senor: stap 4, afbeelding 2 van 3 Zoomer Meowzies Chest Senor Replacement, Chest Senor: stap 4, afbeelding 3 van 3
    • Carefully pry the ribbon cable from the connector.
    • Though we find it easier to use our fingers, the pry-tools may be useful.
  5. Zoomer Meowzies Chest Senor Replacement: stap 5, afbeelding 1 van 3 Zoomer Meowzies Chest Senor Replacement: stap 5, afbeelding 2 van 3 Zoomer Meowzies Chest Senor Replacement: stap 5, afbeelding 3 van 3
    • For easier access to the sensor, tilt and pull the sensor away from the body.
  6. Zoomer Meowzies Chest Senor Replacement: stap 6, afbeelding 1 van 3 Zoomer Meowzies Chest Senor Replacement: stap 6, afbeelding 2 van 3 Zoomer Meowzies Chest Senor Replacement: stap 6, afbeelding 3 van 3
    • To remove the sensors, use a soldering iron to solder the two points and remove the red and black wires from the reverse side.
    • The soldering iron is very hot, so take caution not to touch it directly in order to avoid burns.
  7. Zoomer Meowzies Chest Senor Replacement: stap 7, afbeelding 1 van 2 Zoomer Meowzies Chest Senor Replacement: stap 7, afbeelding 2 van 2
    • Turn the sensors over and locate the solder points of the remaining white wires. Heat the solder and remove the pair of wires.
    • The sensor should be completely detachable now.
Conclusie
Mitchell Gentry
675 Reputatie
6 handleidingen geschreven
USF Tampa, Team S6-G2, Eyestone Spring 2018 Lid van USF Tampa, Team S6-G2, Eyestone Spring 2018
USFT-EYESTONE-S18S6G2
3 Leden
16 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 6
Altijd: 480
