Inleiding
This guide will go over how to remove and replace the batteries in Zoomer Meowzies. Batteries should be removed before starting any guide to avoid an electric shock, and should only be re-inserted once guide is completely finished.
Wat je nodig hebt
Turn the Zoomer Meowzies over so it is on its back and its stomach is facing up.
Using the Phillips #1 screwdriver, loosen the screw holding the battery compartment closed.
Bijna klaar!
Conclusie
