Ga door naar hoofdinhoud
Zoomer Meowzies Battery Replacement
Wat je nodig hebt
  1. Zoomer Meowzies Battery Replacement, Battery: stap 1, afbeelding 1 van 2 Zoomer Meowzies Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Turn the Zoomer Meowzies over so it is on its back and its stomach is facing up.
    • Using the Phillips #1 screwdriver, loosen the screw holding the battery compartment closed.
    • This screw has a collar that will prevent it from being completely removed and therefore cannot be measured or replaced.
  2. Zoomer Meowzies Battery Replacement: stap 2, afbeelding 1 van 2 Zoomer Meowzies Battery Replacement: stap 2, afbeelding 2 van 2
    • Lift the compartment cover from the body. Due to the ribbon on the cover, the batteries should pop out as you remove the cover.
    • Replace with new batteries using the diagrams located within the compartment as a guide for correct battery orientation.
    • When replacing the batteries, weave the ribbon under each battery for easy removal later.
Conclusie
Mitchell Gentry
675 Reputatie
6 handleidingen geschreven
USF Tampa, Team S6-G2, Eyestone Spring 2018 Lid van USF Tampa, Team S6-G2, Eyestone Spring 2018
USFT-EYESTONE-S18S6G2
3 Leden
16 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 22
Altijd: 873
