Ga door naar hoofdinhoud
Zoomer Jurassic World Indominus Rex Nose Sensors Replacement
Wat je nodig hebt
  1. Zoomer Jurassic World Indominus Rex Nose Sensors Replacement, Mouth Part: stap 1, afbeelding 1 van 2 Zoomer Jurassic World Indominus Rex Nose Sensors Replacement, Mouth Part: stap 1, afbeelding 2 van 2
    • Flip the toy over to gain direct access to the first screws you need to remove for the replacement.
    • Remove the two (2) 7.5mm phillips screws using Phillips #1 screwdriver from the bottom of the jaw.
    • Remove the two (2) 7.2mm phillips screws using Phillips #0 screwdriver from the bottom of the jaw.
    • Gently remove the entire bottom jaw piece.
  2. Zoomer Jurassic World Indominus Rex Nose Sensors Replacement: stap 2, afbeelding 1 van 3 Zoomer Jurassic World Indominus Rex Nose Sensors Replacement: stap 2, afbeelding 2 van 3 Zoomer Jurassic World Indominus Rex Nose Sensors Replacement: stap 2, afbeelding 3 van 3
    • Remove the 7.5mm phillips screw using Phillips #1 screwdriver from the middle of the tongue.
    • Using a spudger, gently pry the tongue out of the mouth.
  3. Zoomer Jurassic World Indominus Rex Nose Sensors Replacement, Nose Sensors: stap 3, afbeelding 1 van 2 Zoomer Jurassic World Indominus Rex Nose Sensors Replacement, Nose Sensors: stap 3, afbeelding 2 van 2
    • Carefully, pull out the circuit board that has the three nose sensors attached.
    • You're almost done! The only thing left to do is to use a soldering iron to remove the six (6) wires connected to the circuit board.
    • Use caution when soldering to avoid being burned.
Conclusie
Luke Selby
636 Reputatie
4 handleidingen geschreven
USF Tampa, Team 10-3, Remmell Spring 2016 Lid van USF Tampa, Team 10-3, Remmell Spring 2016
USFT-REMMELL-S16S10G3
4 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 362
