Ga door naar hoofdinhoud
Zoomer Dino Boomer Back Button Replacement
Wat je nodig hebt
  1. Zoomer Dino Boomer Back Button Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Power off Zoomer Dino Boomer before disassembly.
    • Remove the eight 9.3mm Phillips #1 screws.
  2. Zoomer Dino Boomer Back Button Replacement: stap 2, afbeelding 1 van 2 Zoomer Dino Boomer Back Button Replacement: stap 2, afbeelding 2 van 2
    • Turn dinosaur over and hold upright.
    • Use the spudger to pry apart the back cover from the remainder of the Zoomer Dino Boomer.
    • Be gentle while removing the back cover. The back cover of the Zoomer Dino Boomer is still connected to the electronic system by a wire.
  3. Zoomer Dino Boomer Back Button Replacement: stap 3, afbeelding 1 van 3 Zoomer Dino Boomer Back Button Replacement: stap 3, afbeelding 2 van 3 Zoomer Dino Boomer Back Button Replacement: stap 3, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Disconnect the wire that connects the back cover of the dino to the main circuit board by carefully pulling on the orange wire connector with tweezers.
    • Remove back cover.
    • If you are having difficulty removing the connector from its socket, push in the small tabs on the side of the connector with the tweezers. This step may take some work.
    • Do not damage the wires or circuit board.
  4. Zoomer Dino Boomer Back Button Replacement, Back Button: stap 4, afbeelding 1 van 1
    • Where the button is largest, squeeze the two white tabs together.
  5. Zoomer Dino Boomer Back Button Replacement: stap 5, afbeelding 1 van 1
    • Push in the white circular piece between these tabs as far as it will go.
  6. Zoomer Dino Boomer Back Button Replacement: stap 6, afbeelding 1 van 2 Zoomer Dino Boomer Back Button Replacement: stap 6, afbeelding 2 van 2
    • Where the button is smallest, squeeze the two white tabs together and press the circular tab in-between them until the button comes loose.
    • Remove the back button.
Conclusie
Lauren Mannix
398 Reputatie
3 handleidingen geschreven
USF Tampa, Team 16-1, Wollert Fall 2015 Lid van USF Tampa, Team 16-1, Wollert Fall 2015
USFT-WOLLERT-F15S16G1
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 13
Altijd: 2,037
