Ga door naar hoofdinhoud
Zoom Q3HD Handy Video Recorder Lens Cleaning
Wat je nodig hebt
  1. Zoom Q3HD Handy Video Recorder Lens Cleaning, Zoom Q3HD Handy Video Recorder Lens Cleaning: stap 1, afbeelding 1 van 1
    • Remove the two screws from the bottom of the device.
    • Make sure to put your screws in a safe place.
  2. Zoom Q3HD Handy Video Recorder Lens Cleaning: stap 2, afbeelding 1 van 1
    • Flip the device over and remove the four screws bordering the grate of the device.
  3. Zoom Q3HD Handy Video Recorder Lens Cleaning: stap 3, afbeelding 1 van 1
    • On the front of the device, slide the battery compartment cover off by pushing inward and sliding downward.
  4. Zoom Q3HD Handy Video Recorder Lens Cleaning: stap 4, afbeelding 1 van 1
    • Remove the two screws from the lip of the battery compartment.
  5. Zoom Q3HD Handy Video Recorder Lens Cleaning: stap 5, afbeelding 1 van 1
    • Remove the final screw from the bed of the battery compartment.
  6. Zoom Q3HD Handy Video Recorder Lens Cleaning: stap 6, afbeelding 1 van 1
    • WARNING: Pieces may become loose when you separate the device in half!
    • Run the pry tool along the edges of the device to begin separating the device in two halves.
  7. Zoom Q3HD Handy Video Recorder Lens Cleaning: stap 7, afbeelding 1 van 2 Zoom Q3HD Handy Video Recorder Lens Cleaning: stap 7, afbeelding 2 van 2
    • REMINDER: Pieces may become loose when you separate the device in half!
    • Apply upward pressure to fully separate the device into two halves.
  8. Zoom Q3HD Handy Video Recorder Lens Cleaning: stap 8, afbeelding 1 van 1
    • WARNING: If you’re not careful with keeping the screen close to the board, you will rip off the ribbon attaching the screen to the circuit board.
    • Lift display screen keeping the top half close to the board.
  9. Zoom Q3HD Handy Video Recorder Lens Cleaning: stap 9, afbeelding 1 van 1
    • Gently flip the black clip up attaching the ribbon of the screen to the circuit board.
  10. Zoom Q3HD Handy Video Recorder Lens Cleaning: stap 10, afbeelding 1 van 1
    • Gently slide the ribbon from the circuit board, removing the screen.
Conclusie
Grace Bently
4 Reputatie
1 Handleiding geschreven
Ohio State, Team 1-1, Mccook Fall 2014 Lid van Ohio State, Team 1-1, Mccook Fall 2014
OSU-MCCOOK-F14S1G1
4 Leden
1 handleiding geschreven
3 opmerkingen
My zoom q3HD only have the red light turned on when powering up. No display at all. What is happening? How can I claim warranty? I didn't use the device more than a year. Help me
stancalvin - Antwoord
This is not comlete, leaves you half way through, would be great if you could finish this, thank you.
smoldas.l - Antwoord
Yes it would be good to see it finished. I am half way through taking mine apart to clean the lens amd i don't know if i should proceed or not. Its the 2nd time the lens has fogged up. My 2nd q3hd.
steven kemsley - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 10
Altijd: 1,944
