Ga door naar hoofdinhoud
Zoom H6 Handy Recorder Screen Replacement
Wat je nodig hebt
  1. Zoom H6 Handy Recorder Screen Replacement, Case: stap 1, afbeelding 1 van 3 Zoom H6 Handy Recorder Screen Replacement, Case: stap 1, afbeelding 2 van 3 Zoom H6 Handy Recorder Screen Replacement, Case: stap 1, afbeelding 3 van 3
    • Place device face up and pry off the four knobs using the flat end of the plastic opening tool.
    • You may need to stabilize the device with the other hand.
  2. Zoom H6 Handy Recorder Screen Replacement: stap 2, afbeelding 1 van 3 Zoom H6 Handy Recorder Screen Replacement: stap 2, afbeelding 2 van 3 Zoom H6 Handy Recorder Screen Replacement: stap 2, afbeelding 3 van 3
    • With device facedown, lift the four rubber feet from the device using tweezers or fingernails.
  3. Zoom H6 Handy Recorder Screen Replacement: stap 3, afbeelding 1 van 2 Zoom H6 Handy Recorder Screen Replacement: stap 3, afbeelding 2 van 2
    • With device still facedown, unscrew six (PH #1), 9mm screws; two located in center of back side of device right above the battery cover, and four under the rubber feet.
    • An electronics screwdriver small enough to fit in hole (4mm diameter), but long enough to reach the screws (at least 2cm) will be required to unscrew the screws.
  4. Zoom H6 Handy Recorder Screen Replacement: stap 4, afbeelding 1 van 3 Zoom H6 Handy Recorder Screen Replacement: stap 4, afbeelding 2 van 3 Zoom H6 Handy Recorder Screen Replacement: stap 4, afbeelding 3 van 3
    • With the bottom of the device on a table, lift the top of the device and gently place it aside.
  5. Zoom H6 Handy Recorder Screen Replacement, Screen: stap 5, afbeelding 1 van 3 Zoom H6 Handy Recorder Screen Replacement, Screen: stap 5, afbeelding 2 van 3 Zoom H6 Handy Recorder Screen Replacement, Screen: stap 5, afbeelding 3 van 3
    • Unscrew three (PH #1), 7 mm screws (two on right side of display and one on the bottom left).
  6. Zoom H6 Handy Recorder Screen Replacement: stap 6, afbeelding 1 van 3 Zoom H6 Handy Recorder Screen Replacement: stap 6, afbeelding 2 van 3 Zoom H6 Handy Recorder Screen Replacement: stap 6, afbeelding 3 van 3
    • Lift the button board gently to reveal the ribbon connector.
  7. Zoom H6 Handy Recorder Screen Replacement: stap 7, afbeelding 1 van 3 Zoom H6 Handy Recorder Screen Replacement: stap 7, afbeelding 2 van 3 Zoom H6 Handy Recorder Screen Replacement: stap 7, afbeelding 3 van 3
    • Using a plastic opening tool, unlatch the clip and carefully unplug the ribbon connector from the device .
    • Set the button board aside.
  8. Zoom H6 Handy Recorder Screen Replacement: stap 8, afbeelding 1 van 3 Zoom H6 Handy Recorder Screen Replacement: stap 8, afbeelding 2 van 3 Zoom H6 Handy Recorder Screen Replacement: stap 8, afbeelding 3 van 3
    • Use a plastic opening tool to lift the screen from the the backing.
    • Replace the screen.
    • Make sure to not touch the screen directly as it will leave smudges.
    • If need be, the ribbon for the screen could also be replaced during this step.
Conclusie
10 andere personen hebben deze handleiding voltooid.
William D'Arrigo
281 Reputatie
2 handleidingen geschreven
USF Tampa, Team S5-G2, Eyestone Spring 2018 Lid van USF Tampa, Team S5-G2, Eyestone Spring 2018
USFT-EYESTONE-S18S5G2
4 Leden
10 handleidingen geschreven
26 opmerkingen
Hello.
I-m so glad to find this tutorial.
I just have one question, do you know where can i get a LCD screen for my zoom H6. I live in France, i’ve been looking for it on the web but nothing. Thankyou for your help.
pernimatic - Antwoord
Hey friend, check bellow.
Hadrien -
Hi, I have the same question, where can I get the display? in the zoom support they do not respond. Thanks
Jonathan Race - Antwoord
Hi guys, same problem. I just found this, could it be this screen ? http://www.hktdc.com/suppliers-products/...
Hadrien - Antwoord
Hi guys, I found my H6 screen here : https://shop.audiotronic.fr/fr/ The team is very nice and helpful, don’t hesitate to call them.
Hadrien - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 48
Afgelopen 30 dagen: 170
Altijd: 8,120
