Ga door naar hoofdinhoud
Zoom H6 Handy Recorder Motherboard Replacement
Wat je nodig hebt
  1. Zoom H6 Handy Recorder Motherboard Replacement, Case: stap 1, afbeelding 1 van 3 Zoom H6 Handy Recorder Motherboard Replacement, Case: stap 1, afbeelding 2 van 3 Zoom H6 Handy Recorder Motherboard Replacement, Case: stap 1, afbeelding 3 van 3
    • Place device face up and pry off the four knobs using the flat end of the plastic opening tool.
    • You may need to stabilize the device with the other hand.
  2. Zoom H6 Handy Recorder Motherboard Replacement: stap 2, afbeelding 1 van 3 Zoom H6 Handy Recorder Motherboard Replacement: stap 2, afbeelding 2 van 3 Zoom H6 Handy Recorder Motherboard Replacement: stap 2, afbeelding 3 van 3
    • With device facedown, lift the four rubber feet from the device using tweezers or fingernails.
  3. Zoom H6 Handy Recorder Motherboard Replacement: stap 3, afbeelding 1 van 2 Zoom H6 Handy Recorder Motherboard Replacement: stap 3, afbeelding 2 van 2
    • With device still facedown, unscrew six (PH #1), 9mm screws; two located in center of back side of device right above the battery cover, and four under the rubber feet.
    • An electronics screwdriver small enough to fit in hole (4mm diameter), but long enough to reach the screws (at least 2cm) will be required to unscrew the screws.
  4. Zoom H6 Handy Recorder Motherboard Replacement: stap 4, afbeelding 1 van 3 Zoom H6 Handy Recorder Motherboard Replacement: stap 4, afbeelding 2 van 3 Zoom H6 Handy Recorder Motherboard Replacement: stap 4, afbeelding 3 van 3
    • With the bottom of the device on a table, lift the top of the device and gently place it aside.
  5. Zoom H6 Handy Recorder Motherboard Replacement, Motherboard: stap 5, afbeelding 1 van 3 Zoom H6 Handy Recorder Motherboard Replacement, Motherboard: stap 5, afbeelding 2 van 3 Zoom H6 Handy Recorder Motherboard Replacement, Motherboard: stap 5, afbeelding 3 van 3
    • Unscrew three (PH #1), 7mm screws from the display backing and gently flip over.
  6. Zoom H6 Handy Recorder Motherboard Replacement: stap 6, afbeelding 1 van 3 Zoom H6 Handy Recorder Motherboard Replacement: stap 6, afbeelding 2 van 3 Zoom H6 Handy Recorder Motherboard Replacement: stap 6, afbeelding 3 van 3
    • Using a plastic opening tool, unlatch the clip and carefully unplug the ribbon connector from the device.
    • Set the button board aside.
  7. Zoom H6 Handy Recorder Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Unscrew four (PH #1), 8mm screws from the motherboard.
  8. Zoom H6 Handy Recorder Motherboard Replacement: stap 8, afbeelding 1 van 1
    • Disconnect wire from motherboard using tweezers.
    • Do not touch the motherboard with metal tweezers. Only touch the plastic part of the plugged-in wire.
  9. Zoom H6 Handy Recorder Motherboard Replacement: stap 9, afbeelding 1 van 1
    • Turn device 180 degrees to unscrew two (PH #1), 8mm screws from the mic connector.
  10. Zoom H6 Handy Recorder Motherboard Replacement: stap 10, afbeelding 1 van 3 Zoom H6 Handy Recorder Motherboard Replacement: stap 10, afbeelding 2 van 3 Zoom H6 Handy Recorder Motherboard Replacement: stap 10, afbeelding 3 van 3
    • Gently remove three ribbon connectors from the device.
    • The first is connected to the mic connector.
    • The second is connected to the base of the device, and the third is connected to the power switch on the side of the device; turn the device 180 degrees, and the connectors are near the top of the device next to the "LINE OUT" plug-in (directly behind the device display).
    • It's best to use tweezers to remove the two ribbon connectors behind the display.
    • Avoid touching anything but the ribbon connectors with the metal tweezers.
  11. Zoom H6 Handy Recorder Motherboard Replacement: stap 11, afbeelding 1 van 2 Zoom H6 Handy Recorder Motherboard Replacement: stap 11, afbeelding 2 van 2
    • Gently lift the motherboard from the base of the device and set aside.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Cheryl Avery
397 Reputatie
1 Handleiding geschreven
USF Tampa, Team S5-G2, Eyestone Spring 2018 Lid van USF Tampa, Team S5-G2, Eyestone Spring 2018
USFT-EYESTONE-S18S5G2
4 Leden
10 handleidingen geschreven
13 opmerkingen
Good night Mr.
I have a H6 recorder H.6 handy recorder, never use, but the battery stay in and it leak in the box.
When i remove the leaking battery, and i renew the battery the recorder did not start. According a technician the aparatus have to be open and chance the plate, but we does not have those technician on the island. please advice.
Edgar.
leito - Antwoord
hello, i just have a question, where can i find this parts?
tahitibob57 - Antwoord
Can i get Zoom H6 Handy Recorder Motherboard only i need it and the price
Adebanjo Sulaimon - Antwoord
What was the problem? How do you diagnose a bad LCD screen? My screen goes white and nothing else comes on. So there is power, but nothing comes on the screen but the white background.
Caro - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 26
Afgelopen 30 dagen: 104
Altijd: 8,035
