Inleiding
The visible parts of the input jacks are located on the top sides of the device. The top left side contains inputs 1 and 2 while the top right side contains inputs 3 and 4. To replace the inputs, the removal of the button circuit board and the motherboard are required.
Wat je nodig hebt
Place device face up and pry off the four knobs using the flat end of the plastic opening tool.
Unscrew three (PH #1), 7mm screws from the display backing and gently flip over.
Gently remove three ribbon connectors from the device.
The first is connected to the mic connector.
The second is connected to the base of the device, and the third is connected to the power switch on the side of the device; turn the device 180 degrees, and the connectors are near the top of the device next to the "LINE OUT" plug-in (directly behind the device display).
