Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Remove the battery cover, pressing down on the tabs and sliding.
Unscrew the two (2) #00, 10 mm screws located below the mic on the back cover.
Carefully pry up the top end of the back cover using one finger.
Remove the back plate by using a plastic removal tool to pry the back cover up around the edges.
De-solder the red and white leads of the microphone from their solder points.
Solder points are located on the blue circuit board just above the black shielding.
Unscrew the blue circuit board.
The board is held down by a single screw located at the bottom of the device, just to the left of the lowest battery terminal.
Use the plastic removal tool to gently pry up the blue circuit board, allowing access to the microphones.
Use a plastic removal tool to pull the microphone casing off of its post.
Insert the tip of the angled tweezers into the hole in the black plastic located within the microphone case. Use the tweezers to pull the microphone out of the casing.
Remove the faulty microphone by pulling the leads through the black plastic insert.
Insert the leads of the new microphone into the plastic insert and reinsert into the silver microphone casing.
Re-attach the microphone case to the post it came off of.
Solder the leads of the new microphones to the same spots on the blue circuit board.
Ensure that each white lead is soldered to the solder point closest to each edge of its corresponding side, while each red lead is soldered to the inner point on its corresponding side.
5 andere personen hebben deze handleiding voltooid.
5 opmerkingen
Thanks for the procedure. but you did not say where to get the new microphones from. What kind of microphone should we buy and where can they be bought from.
What kind of microphone should we buy and where can they be bought from. I need information.
Attention! There are differet versions of this Rocorder. My H1 had a 3rd screw under the SerialNo. lable, you have to remove first.
mine also has a third screw near the battery, under the serial number. where to buy a new microphone?
Please insert in the guide some link to buy the replacement mic
