Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Remove the two screws on the bottom using a Phillips #00 screwdriver.
Using a spudger, start prying the case apart by working around the edge slowly.
Peel back the touch interface chip (which is on the top right of the motherboard, covered in yellow tape.)
Flip up the small gate and unplug the ribbon cable shown.
Using a Phillips #00 screwdriver, remove the screws highlighted with the orange rings as shown in the picture.
Slide back the plastic latch for the main display cable.
Carefully unplug the cable with tweezers.
Slide back the plastic latch for the camera cable.
Lift up the motherboard assembly, starting by lifting up the top.
Peel back the adhesive tape holding the camera in place.
Remove the camera from the device.
Één andere persoon heeft deze handleiding voltooid.
