Ga door naar hoofdinhoud
Fix Your Stuff
Right to Repair
Parts & Tools
Inleiding
Before you begin this guide, make sure to have the proper tools. You will need a spudger, and a phillips head #00 screwdriver. If you're having trouble with the battery in your device, removing the back panel is one of the first steps in replacing the battery.
Onderdelen
Geen onderdelen opgegeven.
  1. Remove the two screws on the bottom using a Phillips #00 screwdriver.
    • Remove the two screws on the bottom using a Phillips #00 screwdriver.
    • For differentiation purposes, these screws are 4mm long.
  2. Using a spudger, start prying the case apart by working around the edge slowly. Be careful not to damage any of the latches that hold the back panel in place, especially if you are using a metal spudger. While prying, be careful to not lose the power and volume buttons; the case is the only thing holding them in place so they will easily come out once the panel has been removed
    • Using a spudger, start prying the case apart by working around the edge slowly.
    • Be careful not to damage any of the latches that hold the back panel in place, especially if you are using a metal spudger.
    • While prying, be careful to not lose the power and volume buttons; the case is the only thing holding them in place so they will easily come out once the panel has been removed
    • Be careful to not damage the speaker cables, they will still be connecting both panels.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Nicholas Davis
318 Reputatie
2 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 94
