Ga door naar hoofdinhoud
Zenbre SoundBank Z3 Speaker Replacement
Wat je nodig hebt
  1. Zenbre SoundBank Z3 Speaker Replacement, Bottom Cover: stap 1, afbeelding 1 van 2 Zenbre SoundBank Z3 Speaker Replacement, Bottom Cover: stap 1, afbeelding 2 van 2
    • Power off the SoundBank Z3.
    • Turn over the device.
    • Peel the silicone feet up to remove.
    • No extra adhesive is needed to reapply the feet as long as the sticky side is not touched.
  2. Zenbre SoundBank Z3 Speaker Replacement: stap 2, afbeelding 1 van 1
    • Remove all eight of the 11 mm Phillips screws from the bottom of the device.
  3. Zenbre SoundBank Z3 Speaker Replacement: stap 3, afbeelding 1 van 2 Zenbre SoundBank Z3 Speaker Replacement: stap 3, afbeelding 2 van 2
    • Remove the bottom panel speaker using an iFixit opening tool.
  4. Zenbre SoundBank Z3 Speaker Replacement, Motherboard Cover: stap 4, afbeelding 1 van 3 Zenbre SoundBank Z3 Speaker Replacement, Motherboard Cover: stap 4, afbeelding 2 van 3 Zenbre SoundBank Z3 Speaker Replacement, Motherboard Cover: stap 4, afbeelding 3 van 3
    • Remove the four 4.5 mm silver Phillips screws that secure the plastic panel covering the motherboard.
    • Remove the plastic panel.
  5. Zenbre SoundBank Z3 Speaker Replacement, Speakers: stap 5, afbeelding 1 van 2 Zenbre SoundBank Z3 Speaker Replacement, Speakers: stap 5, afbeelding 2 van 2
    • Remove the three screws that are holding the speaker down.
    • Be careful not to rip out the speaker while taking out the screws.
  6. Zenbre SoundBank Z3 Speaker Replacement: stap 6, afbeelding 1 van 2 Zenbre SoundBank Z3 Speaker Replacement: stap 6, afbeelding 2 van 2
    • Desolder the speaker joints from the motherboard. Follow this How To Solder guide for help with desoldering.
  7. Zenbre SoundBank Z3 Speaker Replacement: stap 7, afbeelding 1 van 2 Zenbre SoundBank Z3 Speaker Replacement: stap 7, afbeelding 2 van 2
    • Remove the speaker from the motherboard.
    • Remove the speaker ring.
    • Be careful not to remove other components in the speaker.
    • Repeat Steps 5-7 with the other speaker.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Cherian Thomas
334 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 3-2, Bhusal Spring 2016 Lid van UMass Dartmouth, Team 3-2, Bhusal Spring 2016
UMASSD-BHUSAL-S16S3G2
5 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 459
