Ga door naar hoofdinhoud
Zenbre SoundBank Z3 Speaker Grill Replacement
Wat je nodig hebt
  1. Zenbre SoundBank Z3 Speaker Grill Replacement, Bottom Cover: stap 1, afbeelding 1 van 2 Zenbre SoundBank Z3 Speaker Grill Replacement, Bottom Cover: stap 1, afbeelding 2 van 2
    • Power off the SoundBank Z3.
    • Turn over the device.
    • Peel the silicone feet up to remove.
    • No extra adhesive is needed to reapply the feet as long as the sticky side is not touched.
  2. Zenbre SoundBank Z3 Speaker Grill Replacement: stap 2, afbeelding 1 van 1
    • Remove all eight of the 11 mm Phillips screws from the bottom of the device.
  3. Zenbre SoundBank Z3 Speaker Grill Replacement: stap 3, afbeelding 1 van 2 Zenbre SoundBank Z3 Speaker Grill Replacement: stap 3, afbeelding 2 van 2
    • Remove the bottom panel speaker using an iFixit opening tool.
  4. Zenbre SoundBank Z3 Speaker Grill Replacement, Motherboard Cover: stap 4, afbeelding 1 van 3 Zenbre SoundBank Z3 Speaker Grill Replacement, Motherboard Cover: stap 4, afbeelding 2 van 3 Zenbre SoundBank Z3 Speaker Grill Replacement, Motherboard Cover: stap 4, afbeelding 3 van 3
    • Remove the four 4.5 mm silver Phillips screws that secure the plastic panel covering the motherboard.
    • Remove the plastic panel.
  5. Zenbre SoundBank Z3 Speaker Grill Replacement, Speaker Grill: stap 5, afbeelding 1 van 3 Zenbre SoundBank Z3 Speaker Grill Replacement, Speaker Grill: stap 5, afbeelding 2 van 3 Zenbre SoundBank Z3 Speaker Grill Replacement, Speaker Grill: stap 5, afbeelding 3 van 3
    • Remove the three silver Phillips screws from the plastic ring that holds the speaker in place.
    • Be careful not to rip out the speaker while taking out the screws
    • The same steps can be done on the other side of the speaker
  6. Zenbre SoundBank Z3 Speaker Grill Replacement: stap 6, afbeelding 1 van 3 Zenbre SoundBank Z3 Speaker Grill Replacement: stap 6, afbeelding 2 van 3 Zenbre SoundBank Z3 Speaker Grill Replacement: stap 6, afbeelding 3 van 3
    • First, remove the speaker from the motherboard, then remove the ring that held the speaker in place.
    • These are the joints that need to be soldered. Follow this guide link to help you remove the wires from the motherboard.
    • How To Solder and Desolder Connections
  7. Zenbre SoundBank Z3 Speaker Grill Replacement: stap 7, afbeelding 1 van 2 Zenbre SoundBank Z3 Speaker Grill Replacement: stap 7, afbeelding 2 van 2
    • With the plastic ring removed, the speaker should slide out easily.
    • Be careful not remove other components in the speaker
    • This will expose the speaker grill
  8. Zenbre SoundBank Z3 Speaker Grill Replacement: stap 8, afbeelding 1 van 3 Zenbre SoundBank Z3 Speaker Grill Replacement: stap 8, afbeelding 2 van 3 Zenbre SoundBank Z3 Speaker Grill Replacement: stap 8, afbeelding 3 van 3
    • Now that the speaker has been removed, the plastic grill should be visible.
    • With a little bit of force they can be pushed out.
Conclusie
Luc Josue Pierre Louis
183 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team 3-2, Bhusal Spring 2016 Lid van UMass Dartmouth, Team 3-2, Bhusal Spring 2016
UMASSD-BHUSAL-S16S3G2
5 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 514
