Ga door naar hoofdinhoud
Zeki TBQG884B Rear Case Replacement
Wat je nodig hebt
  1. Zeki TBQG884B Rear Case Replacement, Rear Case: stap 1, afbeelding 1 van 2 Zeki TBQG884B Rear Case Replacement, Rear Case: stap 1, afbeelding 2 van 2
    • Remove the two screws from the end of the device where the ports are located using a Phillips #1 screwdriver.
  2. Zeki TBQG884B Rear Case Replacement: stap 2, afbeelding 1 van 1
    • Place the tablet down so that the screen is facing away from you.
    • Insert the tip of your opening tool into the small gap between the gray and white plastic covering. Pry it open and you should hear the clips opening up.
    • Gently work your way around the perimeter of the tablet's edge.
  3. Zeki TBQG884B Rear Case Replacement: stap 3, afbeelding 1 van 2 Zeki TBQG884B Rear Case Replacement: stap 3, afbeelding 2 van 2
    • Remove the back cover
    • Remove any tape on the speaker and detach the speaker from the back plate.
    • The speaker is connected to the motherboard by two soldered wires. Don't break them when you remove the speaker.
Conclusie
David Wyman
343 Reputatie
3 handleidingen geschreven
IUPUI, Team 1-3, Harley Fall 2015 Lid van IUPUI, Team 1-3, Harley Fall 2015
IUPUI-HARLEY-F15S1G3
5 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 10
Altijd: 360
