Ga door naar hoofdinhoud
Zeki TBQG884B Camera Replacement
Wat je nodig hebt
  1. Zeki TBQG884B Camera Replacement, Rear Case: stap 1, afbeelding 1 van 2 Zeki TBQG884B Camera Replacement, Rear Case: stap 1, afbeelding 2 van 2
    • Remove the two screws from the end of the device where the ports are located using a Phillips #1 screwdriver.
  2. Zeki TBQG884B Camera Replacement: stap 2, afbeelding 1 van 1
    • Place the tablet down so that the screen is facing away from you.
    • Insert the tip of your opening tool into the small gap between the gray and white plastic covering. Pry it open and you should hear the clips opening up.
    • Gently work your way around the perimeter of the tablet's edge.
  3. Zeki TBQG884B Camera Replacement: stap 3, afbeelding 1 van 2 Zeki TBQG884B Camera Replacement: stap 3, afbeelding 2 van 2
    • Remove the back cover
    • Remove any tape on the speaker and detach the speaker from the back plate.
    • The speaker is connected to the motherboard by two soldered wires. Don't break them when you remove the speaker.
  4. Zeki TBQG884B Camera Replacement, Camera: stap 4, afbeelding 1 van 2 Zeki TBQG884B Camera Replacement, Camera: stap 4, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Open the ZIF connector, the black lock part over the wire ribbon in the motherboard, and remove the wire ribbon that connects the motherboard and the camera.
    • The camera is located on the top left, above the motherboard.
    • The camera is usually covered with tape or material. Peel material/tape off with tweezers for safety.
Conclusie
Natalie Holm
137 Reputatie
1 Handleiding geschreven
IUPUI, Team 1-3, Harley Fall 2015 Lid van IUPUI, Team 1-3, Harley Fall 2015
IUPUI-HARLEY-F15S1G3
5 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 11
Altijd: 276
