Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Remove the back casing by slowly popping each tab out with a plastic opening tool.
Remove the tapes one by one from the connecting wires with tweezers.
Remove the black clips from both sides of the casing with a plastic opening tool.
Pull the speakers away from the back casing carefullly.
Detach the motherboard from the framing by removing the four screws using a Phillips #000 screwdriver.
Lift the camera and flash components from their fittings using tweezers.
Lift the metal framing to reach the components at the front of the device.
