Inleiding
This guide will help you to disassemble your tablet and replace your battery. This procedure should take no more then forty minutes to complete. The process will include using a soldering tool and sharp objects.
Onderdelen
Geen onderdelen opgegeven.
Remove the back casing by slowly popping each tab out with a plastic opening tool, such as the one suggested in the "Tools" section.
To remove the battery use an iFixit opening tool to pry the battery apart from the sticky glue.
To insert the new battery, you will need to solder the two new metal tabs back onto the small circuit board.
Please refer to How To Solder and Desolder Connections
Één andere persoon heeft deze handleiding voltooid.
2 Opmerkingen
will this be the same for a tbqc 1065b?
how do i replace the screen mine has cracks?
