Ga door naar hoofdinhoud
Zebra ZP 450 Motherboard Replacement
Wat je nodig hebt
  1. Zebra ZP 450 Motherboard Replacement, Motherboard: stap 1, afbeelding 1 van 1
    • Remove the three 12mm screws from the bottom of the printer using a Phillips #1 screwdriver.
    • Using the TR10 Torx screwdriver, remove the four 8mm screws from the bottom of the device.
  2. Zebra ZP 450 Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Remove the single 7mm screw located underneath the outfeed using the same Phillips #1 screwdriver.
  3. Zebra ZP 450 Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Using an opening pick, pry the plastic covering from around the power button and accessory ports.
  4. Zebra ZP 450 Motherboard Replacement: stap 4, afbeelding 1 van 3 Zebra ZP 450 Motherboard Replacement: stap 4, afbeelding 2 van 3 Zebra ZP 450 Motherboard Replacement: stap 4, afbeelding 3 van 3
    • After lifting the plastic casing from the device, use the Phillips #1 screwdriver to remove the single 5mm screw securing the motherboard.
    • Remove all connections to the motherboard.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 16
Altijd: 427
