Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Onderdelen & Gereedschap
  1. Remove the old line remaining on the Zebco 33 by pressing down on the large spool release button on the back of the reel. Pull the old line off the reel.
    • Remove the old line remaining on the Zebco 33 by pressing down on the large spool release button on the back of the reel. Pull the old line off the reel.
  2. Open the front spool cover of the Zebco 33 reel by turning it to the left and pulling it straight off.
    • Open the front spool cover of the Zebco 33 reel by turning it to the left and pulling it straight off.
  3. Nintendo Switch-kits
    Een snelle oplossing die je weer mee laat doen
    Koop Switchkits
    Koop Switchkits
  4. Cut the line free from the Zebco 33 spool. Pull the line through the front spool cover and then through the line.
    • Cut the line free from the Zebco 33 spool. Pull the line through the front spool cover and then through the line.
  5. Thread the line through the hole in the center of the front spool cover and then around the spool of the reel.
    • Thread the line through the hole in the center of the front spool cover and then around the spool of the reel.
  6. Attach the line to the spool of the Zebco 33 with a knot. Double the knot and then pull the knot down tightly against the spool of the reel. Clip the extra line from the knot.
    • Attach the line to the spool of the Zebco 33 with a knot. Double the knot and then pull the knot down tightly against the spool of the reel. Clip the extra line from the knot.
  7. Put the front spool cover back on the reel. Hold the line a few inches in front of the spool and apply slight tension to the line. Wind the line onto the reel by turning the handle of the reel.
    • Put the front spool cover back on the reel. Hold the line a few inches in front of the spool and apply slight tension to the line. Wind the line onto the reel by turning the handle of the reel.
Conclusie
I have a 33K that I cant get the front cover off. I need advice please jamkauf48@gmail.com
James Kaufman - Antwoord
Instructions need to be much clearer and pictures must be clear.
Functions are difficult to understand……..
Wayne Yeager - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 93
Afgelopen 7 dagen: 701
Afgelopen 30 dagen: 3,283
Altijd: 28,054
