Inleiding
Rather than look out through the large lens while skiing down a mountain, you'd rather watch the world unfold through the LCD viewfinder. Not only is this extremely unsafe, it's impossible if your LCD is broken. Replace your broken LCD and get back to living vicariously through your ski goggles.
  1. In the next few steps, you will be releasing the clips that hold the lens in place. Do not try to completely remove the lens until all the clips have been released. Hold the iON in your hands with your thumbs on the clips next to the middle of the lens.
    • In the next few steps, you will be releasing the clips that hold the lens in place. Do not try to completely remove the lens until all the clips have been released.
    • Hold the iON in your hands with your thumbs on the clips next to the middle of the lens.
    • Pull the rubber housing apart to release the first two clips.
  2. Grab the inside of the plastic nose rest with your thumb and index finger. Rotate the nose rest upwards until you feel that it is free from the lens.
    • Grab the inside of the plastic nose rest with your thumb and index finger.
    • Rotate the nose rest upwards until you feel that it is free from the lens.
  3. Rotate the device 180 degrees. Grab the top of the goggle frame that holds the camera assembly.
    • Rotate the device 180 degrees.
    • Grab the top of the goggle frame that holds the camera assembly.
    • Rotate the frame outwards until you feel that the clips inside it are free.
  4. While firmly holding the goggles with the palm of one hand, grab the top right corner of the frame and rotate it away from the lens. While firmly holding the goggles with the palm of one hand, grab the top right corner of the frame and rotate it away from the lens.
    • While firmly holding the goggles with the palm of one hand, grab the top right corner of the frame and rotate it away from the lens.
  5. The lens should now be barely attached to the frame. If it still feels firmly attached, repeat any necessary steps to free the clips. While holding the goggles in one hand, use the other to grab the lens from opposite ends, and rotate it out of the housing and away from any remaining clips.
    • The lens should now be barely attached to the frame. If it still feels firmly attached, repeat any necessary steps to free the clips.
    • While holding the goggles in one hand, use the other to grab the lens from opposite ends, and rotate it out of the housing and away from any remaining clips.
  6. Remove the four 7.1 mm Phillips screws securing the camera housing to the goggle frame.
    • Remove the four 7.1 mm Phillips screws securing the camera housing to the goggle frame.
  7. Peel back the rubber battery cover from the inner left side of the frame. While firmly holding the battery cover, pull the bottom of the strap mount cover up and off of the frame While firmly holding the battery cover, pull the bottom of the strap mount cover up and off of the frame
    • Peel back the rubber battery cover from the inner left side of the frame.
    • While firmly holding the battery cover, pull the bottom of the strap mount cover up and off of the frame
  8. Once the bottom is free, continue pulling to free the top of the strap mount cover from the frame. Once the bottom is free, continue pulling to free the top of the strap mount cover from the frame.
    • Once the bottom is free, continue pulling to free the top of the strap mount cover from the frame.
  9. Pull the battery out of its recess in the frame. The battery is connected to the entire camera assembly and cannot be completely removed by itself.
    • Pull the battery out of its recess in the frame.
      • The battery is connected to the entire camera assembly and cannot be completely removed by itself.
  10. Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
    Doorblader onze winkel
    Ooit iets gerepareerd? Je bent een genie.
    Deel je reparatie met #ImAGenius
    We zijn allemaal genieën
  11. Peel the rubber keypad cover up from the inner right side of the frame. While firmly holding the keypad cover, pull the top of the strap mount cover up and off of the frame While firmly holding the keypad cover, pull the top of the strap mount cover up and off of the frame
    • Peel the rubber keypad cover up from the inner right side of the frame.
    • While firmly holding the keypad cover, pull the top of the strap mount cover up and off of the frame
  12. Once the bottom is free, continue pulling to free the bottom of the strap mount cover from the frame. Once the bottom is free, continue pulling to free the bottom of the strap mount cover from the frame.
    • Once the bottom is free, continue pulling to free the bottom of the strap mount cover from the frame.
  13. Hold the strap mount cover away from the frame and remove the keypad. Hold the strap mount cover away from the frame and remove the keypad.
    • Hold the strap mount cover away from the frame and remove the keypad.
  14. Grab the viewfinder housing and pull it out of its recess. Just like the battery, the viewfinder housing is connected to the rest of the camera assembly and cannot be removed by itself. Just like the battery, the viewfinder housing is connected to the rest of the camera assembly and cannot be removed by itself.
    • Grab the viewfinder housing and pull it out of its recess.
      • Just like the battery, the viewfinder housing is connected to the rest of the camera assembly and cannot be removed by itself.
  15. Place one of your hands near the center of the frame with your thumb next to the camera housing. With your other hand, grab the camera housing and pull it up and out of the frame. With your other hand, grab the camera housing and pull it up and out of the frame.
    • Place one of your hands near the center of the frame with your thumb next to the camera housing.
    • With your other hand, grab the camera housing and pull it up and out of the frame.
  16. Remove the viewfinder assembly by pulling it through the opening in the top of the frame. Remove the viewfinder assembly by pulling it through the opening in the top of the frame.
    • Remove the viewfinder assembly by pulling it through the opening in the top of the frame.
  17. In the same manner described above, remove the battery from the frame. In the same manner described above, remove the battery from the frame.
    • In the same manner described above, remove the battery from the frame.
  18. Remove the two 7.5 mm Phillips screws on the front of the viewfinder housing. Flip the viewfinder housing over 180 degrees.
    • Remove the two 7.5 mm Phillips screws on the front of the viewfinder housing.
    • Flip the viewfinder housing over 180 degrees.
    • Remove the four 7.1 mm Phillips screws from the back of the viewfinder housing.
  19. Pull the two halves of the viewfinder housing apart. Pull the two halves of the viewfinder housing apart.
    • Pull the two halves of the viewfinder housing apart.
  20. Use the tip of a spudger to flip up the retaining flap on the LCD ribbon cable ZIF connector. Be sure to pry up on the hinged flap, not the connector itself.
    • Use the tip of a spudger to flip up the retaining flap on the LCD ribbon cable ZIF connector.
    • Be sure to pry up on the hinged flap, not the connector itself.
  21. Use the tip of a spudger to push out the retaining clip on the viewfinder backlight ribbon cable ZIF connector. Use the tip of a spudger to push out the retaining clip on the viewfinder backlight ribbon cable ZIF connector.
    • Use the tip of a spudger to push out the retaining clip on the viewfinder backlight ribbon cable ZIF connector.
  22. Using your fingers or tweezers, gently pull out the backlight ribbon cable from its connector on the button board. Using your fingers or tweezers, gently pull out the backlight ribbon cable from its connector on the button board.
    • Using your fingers or tweezers, gently pull out the backlight ribbon cable from its connector on the button board.
  23. Using your fingers or tweezers, remove the LCD ribbon cable from its connector on the button board. Using your fingers or tweezers, remove the LCD ribbon cable from its connector on the button board.
    • Using your fingers or tweezers, remove the LCD ribbon cable from its connector on the button board.
  24. Remove the viewfinder lens assembly from the viewfinder housing. Remove the viewfinder lens assembly from the viewfinder housing.
    • Remove the viewfinder lens assembly from the viewfinder housing.
  25. Use your thumbs to lift the tabs holding the viewfinder lens to the LCD assembly. Pull the viewfinder lens off of the viewfinder LCD.
    • Use your thumbs to lift the tabs holding the viewfinder lens to the LCD assembly.
    • Pull the viewfinder lens off of the viewfinder LCD.
  26. Use your thumb to push the LCD bracket tab away from the LCD. Remove the LCD bracket from the LCD and backlight. Remove the LCD bracket from the LCD and backlight.
    • Use your thumb to push the LCD bracket tab away from the LCD.
    • Remove the LCD bracket from the LCD and backlight.
  27. Using your thumbs, pull the four white tabs on the backlight away from the LCD panel. Remove the LCD from the backlight.
    • Using your thumbs, pull the four white tabs on the backlight away from the LCD panel.
    • Remove the LCD from the backlight.
Conclusie
Eric Flores
128 Reputatie
9 handleidingen geschreven
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 12
Altijd: 1,173
