Inleiding
No one can question the fact that you have the coolest snowboarding video ever. Your Zeal Optics iON goggles perfectly captured you doing a double backflip, landing it, and then riding straight into a tree, cracking the camera lens. Use this guide to replace the broken lens to start recording part 2.
Wat je nodig hebt
Hold the iON in your hands with your thumbs on the clips next to the middle of the lens.
Pull the rubber housing apart to release the first two clips.
Remove the four 7.1 mm Phillips screws securing the camera housing to the goggle frame.
Grab the outer element of the lens and unscrew it by rotating it counterclockwise.
Once the lens is completely unscrewed, remove it from the camera assembly.
