Inleiding
This guide will show you how to remove the logic board from the back of the phone. You will need a plastic opening tool, tweezers, and a #00 Phillips screwdriver to remove the board.
Wat je nodig hebt
Flip the phone over so that the back panel of the phone is facing up.
Wedge the plastic opening tool between the black outer panel and the silver side panel.
Push down on the plastic opening tool to separate the back panel from the rest of the phone.
Continue to do this around all sides of the phone until the back panel has popped all the way off.
Flip the phone over so that the screen is facing up.
Wedge the plastic opening tool between the screen and the rear panel.
Push up on the opening tool to separate the panel from the phone.
Continue to do this around the entire phone until the rear panel is no longer connected to the device.
4 andere personen hebben deze handleiding voltooid.
