Ga door naar hoofdinhoud
ZTE ZMAX Z970 Screen Replacement
Wat je nodig hebt
  1. ZTE ZMAX Z970 Screen Replacement, Battery: stap 1, afbeelding 1 van 2 ZTE ZMAX Z970 Screen Replacement, Battery: stap 1, afbeelding 2 van 2
    • Insert a fine point tool into the hole on the top left side of the phone to remove the SIM and SD card trays.
    • Pull out the trays.
  2. ZTE ZMAX Z970 Screen Replacement: stap 2, afbeelding 1 van 2 ZTE ZMAX Z970 Screen Replacement: stap 2, afbeelding 2 van 2
    • Insert a plastic opening tool into the groove between the phone’s back cover and casing.
    • Move the plastic opening tool along the edges of the phone to unclip the two pieces.
  3. ZTE ZMAX Z970 Screen Replacement: stap 3, afbeelding 1 van 3 ZTE ZMAX Z970 Screen Replacement: stap 3, afbeelding 2 van 3 ZTE ZMAX Z970 Screen Replacement: stap 3, afbeelding 3 van 3
    • Remove the ten 1.2mm screws with a Phillips #000 screwdriver.
  4. ZTE ZMAX Z970 Screen Replacement: stap 4, afbeelding 1 van 2 ZTE ZMAX Z970 Screen Replacement: stap 4, afbeelding 2 van 2
    • Remove the mid frame with the plastic opening tool.
  5. ZTE ZMAX Z970 Screen Replacement: stap 5, afbeelding 1 van 2 ZTE ZMAX Z970 Screen Replacement: stap 5, afbeelding 2 van 2
    • Disconnect the battery from the motherboard.
  6. ZTE ZMAX Z970 Screen Replacement: stap 6, afbeelding 1 van 2 ZTE ZMAX Z970 Screen Replacement: stap 6, afbeelding 2 van 2
    • Wedge a spudger underneath the battery and gently pry upwards to remove the battery.
    • Once free from the glue, remove from device.
    • The glue holding down the battery is strong so work slow and cautiously to avoid starting a fire.
  7. ZTE ZMAX Z970 Screen Replacement, Screen: stap 7, afbeelding 1 van 1
    • Heat up the iOpener for 30 seconds and place on top of the phone for 2 minutes.
  8. ZTE ZMAX Z970 Screen Replacement: stap 8, afbeelding 1 van 1
    • Wedge the opening picks into all the corners of the phone and lift until the screen comes off.
Conclusie
Ismail Jhaveri
159 Reputatie
1 Handleiding geschreven
USF Tampa, Team S17-G3, Boczar Spring 2018 Lid van USF Tampa, Team S17-G3, Boczar Spring 2018
USFT-BOCZAR-S18S17G3
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 6
Altijd: 1,213
