Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
This guide will show you how to remove a defective or broken power button on your ZTE ZMAX smart phone.
  1. Insert a fine point tool into the hole on the top left side of the phone to remove the SIM and SD card trays. Pull out the trays.
    • Insert a fine point tool into the hole on the top left side of the phone to remove the SIM and SD card trays.
    • Pull out the trays.
  2. Insert a plastic opening tool into the groove between the phone’s back cover and casing. Move the plastic opening tool along the edges of the phone to unclip the two pieces.
    • Insert a plastic opening tool into the groove between the phone’s back cover and casing.
    • Move the plastic opening tool along the edges of the phone to unclip the two pieces.
  3. Remove the ten 1.2mm screws with a Phillips #000 screwdriver. Remove the ten 1.2mm screws with a Phillips #000 screwdriver. Remove the ten 1.2mm screws with a Phillips #000 screwdriver.
    • Remove the ten 1.2mm screws with a Phillips #000 screwdriver.
  4. Remove the mid frame with the plastic opening tool. Remove the mid frame with the plastic opening tool.
    • Remove the mid frame with the plastic opening tool.
  5. De essentiƫle toolkit
    De meest behulpzame tools in onze meest compacte kit.
    Koop nu
    Koop nu
  6. Disconnect the battery from the motherboard. Disconnect the battery from the motherboard.
    • Disconnect the battery from the motherboard.
  7. Wedge a spudger underneath the battery and gently pry upwards to remove the battery. Once free from the glue, remove from device.
    • Wedge a spudger underneath the battery and gently pry upwards to remove the battery.
    • Once free from the glue, remove from device.
    • The glue holding down the battery is strong so work slow and cautiously to avoid starting a fire.
  8. Remove the black tape covering the motherboard. Remove the single 1.2mm screw with a Phillips #000 screwdriver. Remove the single 1.2mm screw with a Phillips #000 screwdriver.
    • Remove the black tape covering the motherboard.
    • Remove the single 1.2mm screw with a Phillips #000 screwdriver.
  9. Use the flat end of the spudger to release the upper left and right prongs that secure the motherboard. Detach the antenna cable. Detach the antenna cable.
    • Use the flat end of the spudger to release the upper left and right prongs that secure the motherboard.
    • Detach the antenna cable.
  10. Lift up the tan flap on the three ZIF connectors. Pull the ribbon out of the now unlocked ZIF connectors. Pull the ribbon out of the now unlocked ZIF connectors.
    • Lift up the tan flap on the three ZIF connectors.
    • Pull the ribbon out of the now unlocked ZIF connectors.
  11. Lift the covering panel below the motherboard covering and connecting the power button. Disconnect the circuit tape of the power button and remove the power button.
    • Lift the covering panel below the motherboard covering and connecting the power button.
    • Disconnect the circuit tape of the power button and remove the power button.
    • The power button in these photos has been damaged and not soldered to the motherboard.
    • The new power button will have to be desoldered to the mother board.
Conclusie
Burak Cengiz
480 Reputatie
4 handleidingen geschreven
USF Tampa, Team S17-G3, Boczar Spring 2018 Lid van USF Tampa, Team S17-G3, Boczar Spring 2018
USFT-BOCZAR-S18S17G3
3 Leden
5 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 372
