Ga door naar hoofdinhoud
Inleiding
This guide will show you how to replace the battery on your ZTE ZMAX.
  1. Insert a fine point tool into the hole on the top left side of the phone to remove the SIM and SD card trays. Pull out the trays.
    • Insert a fine point tool into the hole on the top left side of the phone to remove the SIM and SD card trays.
    • Pull out the trays.
  2. Insert a plastic opening tool into the groove between the phone’s back cover and casing. Move the plastic opening tool along the edges of the phone to unclip the two pieces.
    • Insert a plastic opening tool into the groove between the phone’s back cover and casing.
    • Move the plastic opening tool along the edges of the phone to unclip the two pieces.
  3. Remove the ten 1.2mm screws with a Phillips #000 screwdriver. Remove the ten 1.2mm screws with a Phillips #000 screwdriver. Remove the ten 1.2mm screws with a Phillips #000 screwdriver.
    • Remove the ten 1.2mm screws with a Phillips #000 screwdriver.
  4. Remove the mid frame with the plastic opening tool. Remove the mid frame with the plastic opening tool.
    • Remove the mid frame with the plastic opening tool.
  5. Disconnect the battery from the motherboard. Disconnect the battery from the motherboard.
    • Disconnect the battery from the motherboard.
  6. Wedge a spudger underneath the battery and gently pry upwards to remove the battery. Once free from the glue, remove from device.
    • Wedge a spudger underneath the battery and gently pry upwards to remove the battery.
    • Once free from the glue, remove from device.
    • The glue holding down the battery is strong so work slow and cautiously to avoid starting a fire.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Burak Cengiz
480 Reputatie
4 handleidingen geschreven
USF Tampa, Team S17-G3, Boczar Spring 2018 Lid van USF Tampa, Team S17-G3, Boczar Spring 2018
USFT-BOCZAR-S18S17G3
3 Leden
10 handleidingen geschreven
Één commentaar
Although I haven’t yet embarked on this task, I feel more confident in doing so successfully. I have watched the Youtube videos on this and none of them showed such things as the number and placement of the screws. They did give some idea as to the difficulty of it however.
Please continue to produce more of these instructional blurbs.
aikidoronin - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 11
Altijd: 1,278
