Ga door naar hoofdinhoud
ZTE ZFive G LTE Volume and Power Button Replacement
Wat je nodig hebt
  1. ZTE ZFive G LTE Volume and Power Button Replacement, Volume and power button: stap 1, afbeelding 1 van 3 ZTE ZFive G LTE Volume and Power Button Replacement, Volume and power button: stap 1, afbeelding 2 van 3 ZTE ZFive G LTE Volume and Power Button Replacement, Volume and power button: stap 1, afbeelding 3 van 3
    • Remove back cover of the device from the crease of the bottom left corner using opening tool or fingernail.
  2. ZTE ZFive G LTE Volume and Power Button Replacement: stap 2, afbeelding 1 van 2 ZTE ZFive G LTE Volume and Power Button Replacement: stap 2, afbeelding 2 van 2
    • Remove the battery with an opening tool or fingernail.
  3. ZTE ZFive G LTE Volume and Power Button Replacement: stap 3, afbeelding 1 van 2 ZTE ZFive G LTE Volume and Power Button Replacement: stap 3, afbeelding 2 van 2
    • Unscrew all 16 screws from the mid-frame with a J000 screwdriver.
  4. ZTE ZFive G LTE Volume and Power Button Replacement: stap 4, afbeelding 1 van 2 ZTE ZFive G LTE Volume and Power Button Replacement: stap 4, afbeelding 2 van 2
    • Being careful with the device, gently pull up the device body tugging from the inside of the device.
    • Be sure to pull away from the device.
  5. ZTE ZFive G LTE Volume and Power Button Replacement: stap 5, afbeelding 1 van 2 ZTE ZFive G LTE Volume and Power Button Replacement: stap 5, afbeelding 2 van 2
    • Carefully use a pair of bent nose tweezers to pull out the button cover. I should come out easily.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 312
