Ga door naar hoofdinhoud
ZTE ZFive G LTE Front-Facing Camera Replacement
Wat je nodig hebt
  1. ZTE ZFive G LTE Front-Facing Camera  Replacement, Front-Facing Camera: stap 1, afbeelding 1 van 3 ZTE ZFive G LTE Front-Facing Camera  Replacement, Front-Facing Camera: stap 1, afbeelding 2 van 3 ZTE ZFive G LTE Front-Facing Camera  Replacement, Front-Facing Camera: stap 1, afbeelding 3 van 3
    • Using the opening tool, pry open the rear cover from the crease at the bottom left corner.
  2. ZTE ZFive G LTE Front-Facing Camera  Replacement: stap 2, afbeelding 1 van 3 ZTE ZFive G LTE Front-Facing Camera  Replacement: stap 2, afbeelding 2 van 3 ZTE ZFive G LTE Front-Facing Camera  Replacement: stap 2, afbeelding 3 van 3
    • Remove the battery with an opening tool or fingernail.
  3. ZTE ZFive G LTE Front-Facing Camera  Replacement: stap 3, afbeelding 1 van 1
    • Unscrew all 16 screws from the mid-frame J000 screwdriver.
    • Set the screws aside.
  4. ZTE ZFive G LTE Front-Facing Camera  Replacement: stap 4, afbeelding 1 van 2 ZTE ZFive G LTE Front-Facing Camera  Replacement: stap 4, afbeelding 2 van 2
    • Gently pull up the device body from the inside.
    • Make sure to pull on all four sides as shown here.
  5. ZTE ZFive G LTE Front-Facing Camera  Replacement: stap 5, afbeelding 1 van 2 ZTE ZFive G LTE Front-Facing Camera  Replacement: stap 5, afbeelding 2 van 2
    • Once the body is removed, you will see the front facing camera at the top right corner of the device.
    • Using an opening tool, lift up the protective clip on top of the camera's ribbon wire.
  6. ZTE ZFive G LTE Front-Facing Camera  Replacement: stap 6, afbeelding 1 van 2 ZTE ZFive G LTE Front-Facing Camera  Replacement: stap 6, afbeelding 2 van 2
    • Using angled tweezers, gently pull the ribbon wire up from the body.
    • With the ribbon wire out, you should be able to remove the camera.
    • If there is adhesive on the camera backing, it may require more force to pull the camera out.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 340
