Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Pry open the back case to get to the back cover.
Remove eight 5mm screws with a PH0 screw.
Pry open the back cover with a plastic opening tool.
Slide the plastic opening tool alongside the side seam twisting your hand forcefully to open the back cover.
Note: Pry open by finding an edge and forcing it open with the plastic opening tool.
Unplug wires by pushing up with the plastic opening tool
Push up with the plastic opening tool to remove the motherboard.
Slide the plastic opening tool alongside the side seam twisting your hand forcefully to open the motherboard.
Unplug the wire by pushing up with the plastic opening tool in the back of the motherboard.
