Ga door naar hoofdinhoud
ZTE Tempo Front Screen Assembly Replacement
Wat je nodig hebt
  1. ZTE Tempo Front Screen Assembly Replacement, Battery: stap 1, afbeelding 1 van 2 ZTE Tempo Front Screen Assembly Replacement, Battery: stap 1, afbeelding 2 van 2
    • Use a plastic opening tool to pry open the back case.
    • Use a Phillips #0 screwdriver to remove the eight 5mm screws.
    • Use a plastic opening tool to remove the midframe.
  2. ZTE Tempo Front Screen Assembly Replacement: stap 2, afbeelding 1 van 3 ZTE Tempo Front Screen Assembly Replacement: stap 2, afbeelding 2 van 3 ZTE Tempo Front Screen Assembly Replacement: stap 2, afbeelding 3 van 3
    • Use a plastic opening tool to lift the press-fit connector up and disconnect the battery ribbon cable.
    • Lift the battery up and remove it from the phone.
  3. ZTE Tempo Front Screen Assembly Replacement, Front Screen Assembly: stap 3, afbeelding 1 van 3 ZTE Tempo Front Screen Assembly Replacement, Front Screen Assembly: stap 3, afbeelding 2 van 3 ZTE Tempo Front Screen Assembly Replacement, Front Screen Assembly: stap 3, afbeelding 3 van 3
    • Use the plastic opening tool to unplug the three connectors.
  4. ZTE Tempo Front Screen Assembly Replacement: stap 4, afbeelding 1 van 1
    • Use the plastic opening tool to push up on the wire to remove it completely.
  5. ZTE Tempo Front Screen Assembly Replacement: stap 5, afbeelding 1 van 2 ZTE Tempo Front Screen Assembly Replacement: stap 5, afbeelding 2 van 2
    • Insert and slide the plastic opening tool alongside the seam, gently wiggling the opening tool to open and remove the motherboard.
  6. ZTE Tempo Front Screen Assembly Replacement: stap 6, afbeelding 1 van 3 ZTE Tempo Front Screen Assembly Replacement: stap 6, afbeelding 2 van 3 ZTE Tempo Front Screen Assembly Replacement: stap 6, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Use the metal spudger to push up to remove the volume control.
    • Use the tweezers to remove the front speaker and bottom controller.
Conclusie
omar
717 Reputatie
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 319
