Inleiding
If you’ve cracked or damaged the screen of your ZTE Tempo phone, it may be time for a replacement. To complete this replacement, you will need a few tools, so make sure to check the Tools List below before starting this replacement. This guide will help you properly and safely replace the screen on your ZTE Tempo phone.
Wat je nodig hebt
Use a plastic opening tool to pry open the back case.
Use a Phillips #0 screwdriver to remove the eight 5mm screws.
Use a plastic opening tool to remove the midframe.
