Ga door naar hoofdinhoud
ZTE Tempo Front Camera Replacement
Wat je nodig hebt
  1. ZTE Tempo Front Camera Replacement, Front Camera: stap 1, afbeelding 1 van 3 ZTE Tempo Front Camera Replacement, Front Camera: stap 1, afbeelding 2 van 3 ZTE Tempo Front Camera Replacement, Front Camera: stap 1, afbeelding 3 van 3
    • Pry open the back case to get to the back cover.
    • Remove eight 5mm screws with a PH0 screw.
    • Pry open the back cover with a plastic opening tool.
    • Slide the plastic opening tool alongside the side seam twisting your hand forcefully to open the back cover.
    • Note: Pry open by finding an edge and forcing it open with the plastic opening tool.
  2. ZTE Tempo Front Camera Replacement: stap 2, afbeelding 1 van 3 ZTE Tempo Front Camera Replacement: stap 2, afbeelding 2 van 3 ZTE Tempo Front Camera Replacement: stap 2, afbeelding 3 van 3
    • Use a plastic opening tool to lift the press-fit connector up and disconnect the battery ribbon cable.
    • Lift the battery up and remove it from the phone.
  3. ZTE Tempo Front Camera Replacement: stap 3, afbeelding 1 van 2 ZTE Tempo Front Camera Replacement: stap 3, afbeelding 2 van 2
    • Use a plastic opening tool to lift the press-fit connector up and disconnect the front camera ribbon cable.
    • Lift the front camera out of the phone.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 148
