Inleiding
You will be able to replace the keypad on your ZTE Telstra T95. No background information required.
Wat je nodig hebt
Remove the back cover using a plastic opening tool. Insert it into each corner starting at the upper left of the back cover and pushing out.
Unscrew the phone casing using a small screw driver. Remove the four screws on each corner on the back of the phone.
Één andere persoon heeft deze handleiding voltooid.
