Inleiding
Step by step guide to replace the charging port on the ZTE Telstra T95. Soldering background required.
Wat je nodig hebt
Remove the back cover using a plastic opening tool. Insert it into each corner starting at the upper left of the back cover and pushing out.
Unscrew the phone casing using a small screw driver. Remove the four screws on each corner on the back of the phone.
The back casing is removed by taking the motherboard and back casing and pulling them apart.
Gereedschap gebruikt in deze stap:Tweezers$4.99
The charging port is a square piece at the bottom center of the phone that is sticking out.
If it is is loose simply remove it.
If it is still attached you must remove the charging port using the heat pen on your soldering station on top of the charging port until it becomes loose.
Gently remove the charging port using tweezers.
