Ga door naar hoofdinhoud
ZTE Telstra T95 Battery Replacement
Wat je nodig hebt
  1. ZTE Telstra T95 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Remove the back cover using a plastic opening tool. Insert it into each corner starting at the upper left of the back cover and pushing out.
    • You may also use your finger nail if you do not have a plastic opening tool at hand.
    Vraag FixBot
  2. ZTE Telstra T95 Battery Replacement: stap 2, afbeelding 1 van 1
    • Using a plastic opening tool, push out the battery by inserting it into the small groove at the top left corner of the battery and pushing out.
    • The battery snaps out of place and you can remove it using your fingers.
    • When you are ready to insert a battery make sure the three copper teeth on the phone are aligned with the 3 copper dents on the battery.
    Vraag FixBot
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Jeesenia Rios
300 Reputatie
2 handleidingen geschreven
Gateway, Team 1-1, Johnson Fall 2014 Lid van Gateway, Team 1-1, Johnson Fall 2014
GCC-JOHNSON-F14S1G1
3 Leden
12 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 33
Altijd: 657
