Ga door naar hoofdinhoud
ZTE Speed Headphone Jack Replacement
Wat je nodig hebt
  1. ZTE Speed Headphone Jack Replacement, Motherboard: stap 1, afbeelding 1 van 2 ZTE Speed Headphone Jack Replacement, Motherboard: stap 1, afbeelding 2 van 2
    • Pull off back cover at bottom right corner.
  2. ZTE Speed Headphone Jack Replacement: stap 2, afbeelding 1 van 2 ZTE Speed Headphone Jack Replacement: stap 2, afbeelding 2 van 2
    • Remove the seven 3.175mm Phillips head screws from the inner back located at the top, upper-middle-right, middle-right, lower-right, and bottom.
  3. ZTE Speed Headphone Jack Replacement: stap 3, afbeelding 1 van 2 ZTE Speed Headphone Jack Replacement: stap 3, afbeelding 2 van 2
    • With the plastic opening tool the spudger, gently pry off the inner back.
    • Be careful not to pry it off too hard, as it is just a plastic covering.
  4. ZTE Speed Headphone Jack Replacement: stap 4, afbeelding 1 van 1
    • Remove the one 2.381mm Phillips head screw from the motherboard located in the upper-middle part of the phone next to the bottom left corner of the back camera.
  5. ZTE Speed Headphone Jack Replacement: stap 5, afbeelding 1 van 3 ZTE Speed Headphone Jack Replacement: stap 5, afbeelding 2 van 3 ZTE Speed Headphone Jack Replacement: stap 5, afbeelding 3 van 3
    • Using the spudger, gently pry up all ZIF connectors
    • ZIF connectors have a tiny tab that needs to be flipped up in order to safely remove the cable
    • Using same spudger, gently pry up the orange flat top connector
  6. ZTE Speed Headphone Jack Replacement: stap 6, afbeelding 1 van 2 ZTE Speed Headphone Jack Replacement: stap 6, afbeelding 2 van 2
    • Carefully take off motherboard.
  7. ZTE Speed Headphone Jack Replacement, Headphone Jack: stap 7, afbeelding 1 van 2 ZTE Speed Headphone Jack Replacement, Headphone Jack: stap 7, afbeelding 2 van 2
    • Flip over motherboard to locate headphone jack circuit.
Conclusie
Garrett Barry
722 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 6-3, Bhusal Spring 2016 Lid van UMass Dartmouth, Team 6-3, Bhusal Spring 2016
UMASSD-BHUSAL-S16S6G3
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 10
Altijd: 246
