Ga door naar hoofdinhoud
ZTE Speed Front and Back Camera Replacement
Wat je nodig hebt
  1. ZTE Speed Front and Back Camera Replacement, Front and Back Camera: stap 1, afbeelding 1 van 2 ZTE Speed Front and Back Camera Replacement, Front and Back Camera: stap 1, afbeelding 2 van 2
    • Pull off back cover at bottom right corner.
  2. ZTE Speed Front and Back Camera Replacement: stap 2, afbeelding 1 van 2 ZTE Speed Front and Back Camera Replacement: stap 2, afbeelding 2 van 2
    • Remove the seven 3.175mm Phillips head screws from the inner back located at the top, upper-middle-right, middle-right, lower-right, and bottom.
  3. ZTE Speed Front and Back Camera Replacement: stap 3, afbeelding 1 van 2 ZTE Speed Front and Back Camera Replacement: stap 3, afbeelding 2 van 2
    • With the plastic opening tool the spudger, gently pry off the inner back seal around the phone.
    • Be careful not to pry it off too harsh, as it is just plastic.
  4. ZTE Speed Front and Back Camera Replacement: stap 4, afbeelding 1 van 2 ZTE Speed Front and Back Camera Replacement: stap 4, afbeelding 2 van 2
    • With the spudger, gently pry off camera at the top-middle of the phone to get back camera.
    • With the spudger, gently pry off camera at the top-left of the phone to get the front camera.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Garrett Barry
722 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 6-3, Bhusal Spring 2016 Lid van UMass Dartmouth, Team 6-3, Bhusal Spring 2016
UMASSD-BHUSAL-S16S6G3
3 Leden
10 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 395
