Ga door naar hoofdinhoud
ZTE Quest n817 Motherboard Replacement
Wat je nodig hebt
  1. ZTE Quest n817 Motherboard Replacement, Battery: stap 1, afbeelding 1 van 3 ZTE Quest n817 Motherboard Replacement, Battery: stap 1, afbeelding 2 van 3 ZTE Quest n817 Motherboard Replacement, Battery: stap 1, afbeelding 3 van 3
    • Ensure that the phone is turned off before starting.
    • Orient the device so that the inset on the right side of the device is facing you.
    • Insert the spudger into the inset and carefully remove the back panel.
  2. ZTE Quest n817 Motherboard Replacement: stap 2, afbeelding 1 van 2 ZTE Quest n817 Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Use the ribbon to remove the exposed battery.
  3. ZTE Quest n817 Motherboard Replacement, Motherboard: stap 3, afbeelding 1 van 1
    • Use the JIS #000 screwdriver to remove the six 3.0mm screws placed in the back of the ZTE Quest.
  4. ZTE Quest n817 Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Carefully pry open the back panel with the plastic opening tool.
  5. ZTE Quest n817 Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Use a pair of tweezers to gently disconnect the ribbon cable connector from its socket.
  6. ZTE Quest n817 Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Pull back the tape encasing the brown ribbon cable connector.
    • Remove the ribbon cable from its socket.
  7. ZTE Quest n817 Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Unplug the flat-top connector by using a pair of tweezers to pry up each side before removing the connector from its socket.
  8. ZTE Quest n817 Motherboard Replacement: stap 8, afbeelding 1 van 2 ZTE Quest n817 Motherboard Replacement: stap 8, afbeelding 2 van 2
    • Disconnect the coaxial connector in the bottom right corner of the motherboard.
Conclusie
Eric Loureiro
582 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team S3-G6, Peak Fall 2018 Lid van UMass Dartmouth, Team S3-G6, Peak Fall 2018
UMASSD-PEAK-F18S3G6
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 10
Altijd: 482
