Inleiding
The ZTE Quest's daughterboard holds the charging port and the phone's vibration motor. If either of these need to be replaced then this guide will run through the process of removing the daughterboard.
Onderdelen
Geen onderdelen nodig.
  1. Ensure that the phone is turned off before starting.
    • Ensure that the phone is turned off before starting.
    • Orient the device so that the inset on the right side of the device is facing you.
    • Insert the spudger into the inset and carefully remove the back panel.
  2. Use the ribbon to remove the exposed battery.
    • Use the ribbon to remove the exposed battery.
    • Carefully pry open the back panel with the plastic opening tool.
    • Unplug the flat-top connector by lifting each side of the connector up before fully removing it from its socket.
    • Remove the two 2.0mm screws on either side of the daughterboard.
    • Remove the coaxial connector that links the daughterboard to the motherboard.
Conclusie
Eric Loureiro
469 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team S3-G6, Peak Fall 2018 Lid van UMass Dartmouth, Team S3-G6, Peak Fall 2018
UMASSD-PEAK-F18S3G6
3 Leden
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 6
Altijd: 42
