Inleiding
If your ZTE Quest phone can't hold a charge or you're having trouble turning on your phone, then this guide will provide instructions on how to replace your battery.
Wat je nodig hebt
Orient the device so that the inset on the right side of the device is facing you.
Insert the spudger into the inset and carefully remove the back panel.
Één andere persoon heeft deze handleiding voltooid.
