Inleiding
Replacing the back speaker could be beneficial for several reasons. Firstly, if the current speaker produces crackling sounds, distorted audio, or no sound at all, a replacement would restore clear and crisp audio quality, ensuring an enjoyable experience for music, videos, calls, and notifications.
Additionally, if the speaker is damaged due to wear and tear or accidental impact, a replacement becomes necessary to regain the device's full audio functionality.
Lastly, upgrading to a new speaker might offer improved sound performance, enhanced bass, or better volume output, enriching your overall audio experience on the phone.
Wat je nodig hebt
Locate the small indent on the back right bottom corner of the phone.
Put the pry tool or your fingertip inside the small gap on the bottom right of the back of the phone and pop up the cover.
Continue to go around the phone until the cover is completely off the back of the pull and put it aside.
Locate the battery in the middle of the back of the phone.
Push in and up on the battery to remove it from its slot.
Put the battery aside.
Use a Phillips #00 screwdriver to remove twelve 2 mm screws along the back outer edges of the phone.
Put the midframe on its back and locate the speaker on the bottom left corner.
