Ga door naar hoofdinhoud
ZTE Maven 3 Midframe Replacement
Wat je nodig hebt
  1. ZTE Maven 3 Midframe Replacement, Back Cover: stap 1, afbeelding 1 van 3 ZTE Maven 3 Midframe Replacement, Back Cover: stap 1, afbeelding 2 van 3 ZTE Maven 3 Midframe Replacement, Back Cover: stap 1, afbeelding 3 van 3
    • Locate the small indent on the back right bottom corner of the phone.
    • Put the pry tool or your fingertip inside the small gap on the bottom right of the back of the phone and pop up the cover.
    • Continue to go around the phone until the cover is completely off the back of the pull and put it aside.
  2. ZTE Maven 3 Midframe Replacement, Battery: stap 2, afbeelding 1 van 3 ZTE Maven 3 Midframe Replacement, Battery: stap 2, afbeelding 2 van 3 ZTE Maven 3 Midframe Replacement, Battery: stap 2, afbeelding 3 van 3
    • Locate the battery in the middle of the back of the phone.
    • Push in and up on the battery to remove it from its slot.
    • Put the battery aside.
  3. ZTE Maven 3 Midframe Replacement, Midframe: stap 3, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to remove twelve 2 mm screws along the back outer edges of the phone.
  4. ZTE Maven 3 Midframe Replacement: stap 4, afbeelding 1 van 1
    • There’s a 13th 2 mm screw with a lock sticker over it on the bottom right corner. Insert the #00 Phillips screwdriver in the middle, breaking the sticker, and take the screw out.
  5. ZTE Maven 3 Midframe Replacement: stap 5, afbeelding 1 van 2 ZTE Maven 3 Midframe Replacement: stap 5, afbeelding 2 van 2
    • Slide the pry tool into the middle of the connection between the screen and the back of the phone.
    • Once in, slide the pry tool around the phone, separating the screen and the back of the phone.
    • The detached piece is the midframe, and you can place it aside when detached.
Conclusie
Emma Thiboutot
699 Reputatie
8 handleidingen geschreven
UMass Dartmouth, Team 3-1, Konn Fall 2023 Lid van UMass Dartmouth, Team 3-1, Konn Fall 2023
UMASSD-KONN-F23S3G1
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 27
