Ga door naar hoofdinhoud
ZTE Maven 3 Daughterboard Replacement
Wat je nodig hebt
  1. ZTE Maven 3 Daughterboard Replacement, Back Cover: stap 1, afbeelding 1 van 3 ZTE Maven 3 Daughterboard Replacement, Back Cover: stap 1, afbeelding 2 van 3 ZTE Maven 3 Daughterboard Replacement, Back Cover: stap 1, afbeelding 3 van 3
    • Locate the small indent on the back right bottom corner of the phone.
    • Put the pry tool or your fingertip inside the small gap on the bottom right of the back of the phone and pop up the cover.
    • Continue to go around the phone until the cover is completely off the back of the pull and put it aside.
  2. ZTE Maven 3 Daughterboard Replacement, Battery: stap 2, afbeelding 1 van 3 ZTE Maven 3 Daughterboard Replacement, Battery: stap 2, afbeelding 2 van 3 ZTE Maven 3 Daughterboard Replacement, Battery: stap 2, afbeelding 3 van 3
    • Locate the battery in the middle of the back of the phone.
    • Push in and up on the battery to remove it from its slot.
    • Put the battery aside.
  3. ZTE Maven 3 Daughterboard Replacement, Midframe: stap 3, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to remove twelve 2 mm screws along the back outer edges of the phone.
  4. ZTE Maven 3 Daughterboard Replacement: stap 4, afbeelding 1 van 1
    • There’s a 13th 2 mm screw with a lock sticker over it on the bottom right corner. Insert the #00 Phillips screwdriver in the middle, breaking the sticker, and take the screw out.
  5. ZTE Maven 3 Daughterboard Replacement: stap 5, afbeelding 1 van 2 ZTE Maven 3 Daughterboard Replacement: stap 5, afbeelding 2 van 2
    • Slide the pry tool into the middle of the connection between the screen and the back of the phone.
    • Once in, slide the pry tool around the phone, separating the screen and the back of the phone.
    • The detached piece is the midframe, and you can place it aside when detached.
  6. ZTE Maven 3 Daughterboard Replacement, Motherboard: stap 6, afbeelding 1 van 1
    • Use the Phillips #00 screwdriver and remove the four 2 mm screws that are located around the edges.
  7. ZTE Maven 3 Daughterboard Replacement: stap 7, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Please locate the black wire that’s attached to gold plates on the left side of the device.
    • Using a pair of tweezers, carefully grab the black wire and detach it, then remove it.
  8. ZTE Maven 3 Daughterboard Replacement: stap 8, afbeelding 1 van 2 ZTE Maven 3 Daughterboard Replacement: stap 8, afbeelding 2 van 2
    • Using the tweezers, carefully detach the six ribbon cables also located along the edges.
    • 2 adhesive ribbon cables (green circles).
    • One ribbon cable that slides out (orange circles).
    • Three ribbon cables that pop in and out (yellow circles).
  9. ZTE Maven 3 Daughterboard Replacement: stap 9, afbeelding 1 van 3 ZTE Maven 3 Daughterboard Replacement: stap 9, afbeelding 2 van 3 ZTE Maven 3 Daughterboard Replacement: stap 9, afbeelding 3 van 3
    • You will also have to detach the two cameras by detaching the ribbon cable using the tweezers as well. Put those off to the side.
  10. ZTE Maven 3 Daughterboard Replacement: stap 10, afbeelding 1 van 2 ZTE Maven 3 Daughterboard Replacement: stap 10, afbeelding 2 van 2
    • Grab the opening pick and work it into the edges of the motherboard.
    • Make sure you are firmly pushing the pick to loosen the motherboard since it is placed with adhesive.
    • Remove the motherboard and put it aside.
  11. ZTE Maven 3 Daughterboard Replacement, Daughterboard/Charging Port: stap 11, afbeelding 1 van 2 ZTE Maven 3 Daughterboard Replacement, Daughterboard/Charging Port: stap 11, afbeelding 2 van 2
    • Use your fingertips or pry gently with a plastic tool to remove the daughterboard.
Conclusie
Emma Thiboutot
699 Reputatie
8 handleidingen geschreven
UMass Dartmouth, Team 3-1, Konn Fall 2023 Lid van UMass Dartmouth, Team 3-1, Konn Fall 2023
UMASSD-KONN-F23S3G1
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 31
