Ga door naar hoofdinhoud
ZTE Maven 2 Daughterboard Replacement
Wat je nodig hebt
  1. ZTE Maven 2 Daughterboard Replacement, Back Cover: stap 1, afbeelding 1 van 3 ZTE Maven 2 Daughterboard Replacement, Back Cover: stap 1, afbeelding 2 van 3 ZTE Maven 2 Daughterboard Replacement, Back Cover: stap 1, afbeelding 3 van 3
    • Pry off the back cover by inserting an opening tool into the small space on the bottom left between the phone's cover and body.
    • Work your way around the phone with an opening pick to loosen the rest of the back cover.
    • Remove the cover.
  2. ZTE Maven 2 Daughterboard Replacement, Battery: stap 2, afbeelding 1 van 1
    • Push in and then up on the bottom of the battery to free it from its compartment.
    • Pull the battery out.
  3. ZTE Maven 2 Daughterboard Replacement, MicroSD Card: stap 3, afbeelding 1 van 2 ZTE Maven 2 Daughterboard Replacement, MicroSD Card: stap 3, afbeelding 2 van 2
    • Using your fingers or blunt tweezers, carefully pull the memory card out of the slot.
    • A SIM card is used to demonstrate the process for removing the MicroSD card in these images.
  4. ZTE Maven 2 Daughterboard Replacement, Midframe: stap 4, afbeelding 1 van 1
    • Remove the twelve 3 mm screws with a Phillips #00 screwdriver.
  5. ZTE Maven 2 Daughterboard Replacement: stap 5, afbeelding 1 van 3 ZTE Maven 2 Daughterboard Replacement: stap 5, afbeelding 2 van 3 ZTE Maven 2 Daughterboard Replacement: stap 5, afbeelding 3 van 3
    • Wedge the opening tool between the front and side panel to create a gap.
    • Slide the opening pick around the device to detach the midframe.
  6. ZTE Maven 2 Daughterboard Replacement, Motherboard: stap 6, afbeelding 1 van 3 ZTE Maven 2 Daughterboard Replacement, Motherboard: stap 6, afbeelding 2 van 3 ZTE Maven 2 Daughterboard Replacement, Motherboard: stap 6, afbeelding 3 van 3
    • Peel the sticker off the battery compartment, as some of the motherboard components are hidden under it.
    • Remove the six 3 mm screws with a Phillips #00 screwdriver.
    • Using a pair of blunt tweezers, carefully remove the black wire that's attached to the gold plates on the left side of the device.
  7. ZTE Maven 2 Daughterboard Replacement: stap 7, afbeelding 1 van 2 ZTE Maven 2 Daughterboard Replacement: stap 7, afbeelding 2 van 2
    • Using the opening tool, carefully detach the ribbon cables connected to the motherboard.
  8. ZTE Maven 2 Daughterboard Replacement: stap 8, afbeelding 1 van 2 ZTE Maven 2 Daughterboard Replacement: stap 8, afbeelding 2 van 2
    • Work the opening pick around the edges of the motherboard to loosen it up.
    • The motherboard is glued down with adhesive. Pushing firmly with the pick will help to loosen the components and remove them.
    • Pull the motherboard out of the device.
  9. ZTE Maven 2 Daughterboard Replacement, Daughterboard: stap 9, afbeelding 1 van 1
    • Remove the daughterboard containing the charging port.
Conclusie
Kristen Gismondi
82.023 Reputatie
200 handleidingen geschreven
iFixit Lid van iFixit
Staff
135 Leden
17.198 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 21
