Ga door naar hoofdinhoud
ZTE Lever Screen Replacement
Wat je nodig hebt
  1. ZTE Lever Screen Replacement, Battery: stap 1, afbeelding 1 van 1
    • Remove the SD card and the Sim card from the device.
    • The Sim and SD cards are not shown here as our device did not come with them.
  2. ZTE Lever Screen Replacement: stap 2, afbeelding 1 van 2 ZTE Lever Screen Replacement: stap 2, afbeelding 2 van 2
    • Use an iFixit opening tool to separate the back from the device.
  3. ZTE Lever Screen Replacement: stap 3, afbeelding 1 van 2 ZTE Lever Screen Replacement: stap 3, afbeelding 2 van 2
    • Remove the two 1.6mm Phillips #0 screws from the battery plug cover.
    • Remove the cover.
  4. ZTE Lever Screen Replacement: stap 4, afbeelding 1 van 2 ZTE Lever Screen Replacement: stap 4, afbeelding 2 van 2
    • Disconnect the battery cable from the motherboard with a plastic opening tool.
  5. ZTE Lever Screen Replacement: stap 5, afbeelding 1 van 1
    • Use your hands, or a plastic opening tool, to pry the battery from the phone.
  6. ZTE Lever Screen Replacement, Volume Buttons: stap 6, afbeelding 1 van 1
    • Remove the three 1.6mm Phillips #0 screws from the plastic cover on the motherboard.
  7. ZTE Lever Screen Replacement: stap 7, afbeelding 1 van 3 ZTE Lever Screen Replacement: stap 7, afbeelding 2 van 3 ZTE Lever Screen Replacement: stap 7, afbeelding 3 van 3
    • Remove the top plastic motherboard cover using a plastic opening tool.
  8. ZTE Lever Screen Replacement: stap 8, afbeelding 1 van 2 ZTE Lever Screen Replacement: stap 8, afbeelding 2 van 2
    • Use a plastic opening tool to flip up the retaining flap on the volume ribbon cable ZIF socket.
  9. ZTE Lever Screen Replacement: stap 9, afbeelding 1 van 2 ZTE Lever Screen Replacement: stap 9, afbeelding 2 van 2
    • Peel up the volume button cable from the phone with hands, or plastic opening tool.
  10. ZTE Lever Screen Replacement, Power Button: stap 10, afbeelding 1 van 1
    • Disconnect the power button from the motherboard with a plastic opening tool.
  11. ZTE Lever Screen Replacement: stap 11, afbeelding 1 van 2 ZTE Lever Screen Replacement: stap 11, afbeelding 2 van 2
    • Peel the power button cable up from the phone with you hands, or a plastic opening tool.
  12. ZTE Lever Screen Replacement, Motherboard: stap 12, afbeelding 1 van 2 ZTE Lever Screen Replacement, Motherboard: stap 12, afbeelding 2 van 2
    • Remove the seven 1.6mm Phillips #0 screws from the plastic cover on the bottom of the motherboard.
  13. ZTE Lever Screen Replacement: stap 13, afbeelding 1 van 1
    • Remove the bottom plastic motherboard cover with your fingers
  14. ZTE Lever Screen Replacement: stap 14, afbeelding 1 van 2 ZTE Lever Screen Replacement: stap 14, afbeelding 2 van 2
    • Disconnect the camera from the motherboard with a plastic opening tool.
  15. ZTE Lever Screen Replacement: stap 15, afbeelding 1 van 1
    • Disconnect the display cable from the motherboard with a plastic opening tool.
  16. ZTE Lever Screen Replacement: stap 16, afbeelding 1 van 3 ZTE Lever Screen Replacement: stap 16, afbeelding 2 van 3 ZTE Lever Screen Replacement: stap 16, afbeelding 3 van 3
  17. ZTE Lever Screen Replacement: stap 17, afbeelding 1 van 1
    • Disconnect the rear speaker cable from the motherboard with a plastic opening tool.
  18. ZTE Lever Screen Replacement: stap 18, afbeelding 1 van 1
    • Pry the motherboard cell battery from its position on the case of the phone
  19. ZTE Lever Screen Replacement: stap 19, afbeelding 1 van 3 ZTE Lever Screen Replacement: stap 19, afbeelding 2 van 3 ZTE Lever Screen Replacement: stap 19, afbeelding 3 van 3
    • Using the plastic opening tool, pry the motherboard up, sliding along the edge to separate the pieces.
  20. ZTE Lever Screen Replacement: stap 20, afbeelding 1 van 1
    • Remove the motherboard with your fingers.
  21. ZTE Lever Screen Replacement, Screen: stap 21, afbeelding 1 van 2 ZTE Lever Screen Replacement, Screen: stap 21, afbeelding 2 van 2
    • Using the iFixit opening tool, pry off the screen from the case.
    • Be careful not to crack the case.
  22. ZTE Lever Screen Replacement: stap 22, afbeelding 1 van 3 ZTE Lever Screen Replacement: stap 22, afbeelding 2 van 3 ZTE Lever Screen Replacement: stap 22, afbeelding 3 van 3
    • Slide the 2 ribbon cables through their respective holes before separating the case from the screen.
    • Gently lift up the case from the screen.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 6
Altijd: 231
