Ga door naar hoofdinhoud
ZTE Lever Power Button Replacement
Wat je nodig hebt
  1. ZTE Lever Power Button Replacement, Battery: stap 1, afbeelding 1 van 1
    • Remove the SD card and the Sim card from the device.
    • The Sim and SD cards are not shown here as our device did not come with them.
  2. ZTE Lever Power Button Replacement: stap 2, afbeelding 1 van 2 ZTE Lever Power Button Replacement: stap 2, afbeelding 2 van 2
    • Use an iFixit opening tool to separate the back from the device.
  3. ZTE Lever Power Button Replacement: stap 3, afbeelding 1 van 2 ZTE Lever Power Button Replacement: stap 3, afbeelding 2 van 2
    • Remove the two 1.6mm Phillips #0 screws from the battery plug cover.
    • Remove the cover.
  4. ZTE Lever Power Button Replacement: stap 4, afbeelding 1 van 2 ZTE Lever Power Button Replacement: stap 4, afbeelding 2 van 2
    • Disconnect the battery cable from the motherboard with a plastic opening tool.
  5. ZTE Lever Power Button Replacement: stap 5, afbeelding 1 van 1
    • Use your hands, or a plastic opening tool, to pry the battery from the phone.
  6. ZTE Lever Power Button Replacement, Volume Buttons: stap 6, afbeelding 1 van 1
    • Remove the three 1.6mm Phillips #0 screws from the plastic cover on the motherboard.
  7. ZTE Lever Power Button Replacement: stap 7, afbeelding 1 van 3 ZTE Lever Power Button Replacement: stap 7, afbeelding 2 van 3 ZTE Lever Power Button Replacement: stap 7, afbeelding 3 van 3
    • Remove the top plastic motherboard cover using a plastic opening tool.
  8. ZTE Lever Power Button Replacement: stap 8, afbeelding 1 van 2 ZTE Lever Power Button Replacement: stap 8, afbeelding 2 van 2
    • Use a plastic opening tool to flip up the retaining flap on the volume ribbon cable ZIF socket.
  9. ZTE Lever Power Button Replacement: stap 9, afbeelding 1 van 2 ZTE Lever Power Button Replacement: stap 9, afbeelding 2 van 2
    • Peel up the volume button cable from the phone with hands, or plastic opening tool.
  10. ZTE Lever Power Button Replacement, Power Button: stap 10, afbeelding 1 van 1
    • Disconnect the power button from the motherboard with a plastic opening tool.
  11. ZTE Lever Power Button Replacement: stap 11, afbeelding 1 van 2 ZTE Lever Power Button Replacement: stap 11, afbeelding 2 van 2
    • Peel the power button cable up from the phone with you hands, or a plastic opening tool.
Conclusie
Michael Gonzalez
501 Reputatie
4 handleidingen geschreven
USF Tampa, Team S5-G2, Passmore Spring 2018 Lid van USF Tampa, Team S5-G2, Passmore Spring 2018
USFT-PASSMORE-S18S5G2
3 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 202
