Ga door naar hoofdinhoud
ZTE Lever Motherboard Replacement
Wat je nodig hebt
  1. ZTE Lever Motherboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Remove the SD card and the Sim card from the device.
    • The Sim and SD cards are not shown here as our device did not come with them.
  2. ZTE Lever Motherboard Replacement: stap 2, afbeelding 1 van 2 ZTE Lever Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Use an iFixit opening tool to separate the back from the device.
  3. ZTE Lever Motherboard Replacement: stap 3, afbeelding 1 van 2 ZTE Lever Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Remove the two 1.6mm Phillips #0 screws from the battery plug cover.
    • Remove the cover.
  4. ZTE Lever Motherboard Replacement: stap 4, afbeelding 1 van 2 ZTE Lever Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Disconnect the battery cable from the motherboard with a plastic opening tool.
  5. ZTE Lever Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Use your hands, or a plastic opening tool, to pry the battery from the phone.
  6. ZTE Lever Motherboard Replacement, Volume Buttons: stap 6, afbeelding 1 van 1
    • Remove the three 1.6mm Phillips #0 screws from the plastic cover on the motherboard.
  7. ZTE Lever Motherboard Replacement: stap 7, afbeelding 1 van 3 ZTE Lever Motherboard Replacement: stap 7, afbeelding 2 van 3 ZTE Lever Motherboard Replacement: stap 7, afbeelding 3 van 3
    • Remove the top plastic motherboard cover using a plastic opening tool.
  8. ZTE Lever Motherboard Replacement: stap 8, afbeelding 1 van 2 ZTE Lever Motherboard Replacement: stap 8, afbeelding 2 van 2
    • Use a plastic opening tool to flip up the retaining flap on the volume ribbon cable ZIF socket.
  9. ZTE Lever Motherboard Replacement: stap 9, afbeelding 1 van 2 ZTE Lever Motherboard Replacement: stap 9, afbeelding 2 van 2
    • Peel up the volume button cable from the phone with hands, or plastic opening tool.
  10. ZTE Lever Motherboard Replacement, Power Button: stap 10, afbeelding 1 van 1
    • Disconnect the power button from the motherboard with a plastic opening tool.
  11. ZTE Lever Motherboard Replacement: stap 11, afbeelding 1 van 2 ZTE Lever Motherboard Replacement: stap 11, afbeelding 2 van 2
    • Peel the power button cable up from the phone with you hands, or a plastic opening tool.
  12. ZTE Lever Motherboard Replacement, Motherboard: stap 12, afbeelding 1 van 2 ZTE Lever Motherboard Replacement, Motherboard: stap 12, afbeelding 2 van 2
    • Remove the seven 1.6mm Phillips #0 screws from the plastic cover on the bottom of the motherboard.
  13. ZTE Lever Motherboard Replacement: stap 13, afbeelding 1 van 1
    • Remove the bottom plastic motherboard cover with your fingers
  14. ZTE Lever Motherboard Replacement: stap 14, afbeelding 1 van 2 ZTE Lever Motherboard Replacement: stap 14, afbeelding 2 van 2
    • Disconnect the camera from the motherboard with a plastic opening tool.
  15. ZTE Lever Motherboard Replacement: stap 15, afbeelding 1 van 1
    • Disconnect the display cable from the motherboard with a plastic opening tool.
  16. ZTE Lever Motherboard Replacement: stap 16, afbeelding 1 van 3 ZTE Lever Motherboard Replacement: stap 16, afbeelding 2 van 3 ZTE Lever Motherboard Replacement: stap 16, afbeelding 3 van 3
  17. ZTE Lever Motherboard Replacement: stap 17, afbeelding 1 van 1
    • Disconnect the rear speaker cable from the motherboard with a plastic opening tool.
  18. ZTE Lever Motherboard Replacement: stap 18, afbeelding 1 van 1
    • Pry the motherboard cell battery from its position on the case of the phone
  19. ZTE Lever Motherboard Replacement: stap 19, afbeelding 1 van 3 ZTE Lever Motherboard Replacement: stap 19, afbeelding 2 van 3 ZTE Lever Motherboard Replacement: stap 19, afbeelding 3 van 3
    • Using the plastic opening tool, pry the motherboard up, sliding along the edge to separate the pieces.
  20. ZTE Lever Motherboard Replacement: stap 20, afbeelding 1 van 1
    • Remove the motherboard with your fingers.
Conclusie
Luke Kilbourne
294 Reputatie
2 handleidingen geschreven
USF Tampa, Team S5-G2, Passmore Spring 2018 Lid van USF Tampa, Team S5-G2, Passmore Spring 2018
USFT-PASSMORE-S18S5G2
3 Leden
12 handleidingen geschreven
Één opmerking
Those are excellent instructions but I need to know where at on the motherboard is the internal memory storage cuz my phone is so screwed up that it won't charge or turn on or anything lol,so I got a different phone n got my SD card out of the ZTE n put in my new phone and there are some pics that I really need,but I was wondering if there was any way possible that I could put the SD card back in the ZTE motherboard and some how move the pics onto my SD card so I can have them on my new phone.This is killing my brain on trying to think of ways to succeed n can't please get back to me,,,thanks.
-ROGER-
Roger Knight - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 339
