Ga door naar hoofdinhoud
ZTE Lever Front Camera Replacement
Wat je nodig hebt
  1. ZTE Lever Front Camera Replacement, Battery: stap 1, afbeelding 1 van 1
    • Remove the SD card and the Sim card from the device.
    • The Sim and SD cards are not shown here as our device did not come with them.
  2. ZTE Lever Front Camera Replacement: stap 2, afbeelding 1 van 2 ZTE Lever Front Camera Replacement: stap 2, afbeelding 2 van 2
    • Use an iFixit opening tool to separate the back from the device.
  3. ZTE Lever Front Camera Replacement: stap 3, afbeelding 1 van 2 ZTE Lever Front Camera Replacement: stap 3, afbeelding 2 van 2
    • Remove the two 1.6mm Phillips #0 screws from the battery plug cover.
    • Remove the cover.
  4. ZTE Lever Front Camera Replacement: stap 4, afbeelding 1 van 2 ZTE Lever Front Camera Replacement: stap 4, afbeelding 2 van 2
    • Disconnect the battery cable from the motherboard with a plastic opening tool.
  5. ZTE Lever Front Camera Replacement: stap 5, afbeelding 1 van 1
    • Use your hands, or a plastic opening tool, to pry the battery from the phone.
  6. ZTE Lever Front Camera Replacement, Front Camera: stap 6, afbeelding 1 van 2 ZTE Lever Front Camera Replacement, Front Camera: stap 6, afbeelding 2 van 2
    • Unscrew the three 1.6mm Philllips #0 screws on the plastic cover that are near the top edge of the phone by the camera.
    • Pry off the plastic cover using the iFixit opening tool.
  7. ZTE Lever Front Camera Replacement: stap 7, afbeelding 1 van 2 ZTE Lever Front Camera Replacement: stap 7, afbeelding 2 van 2
    • Unplug the front-facing camera press fit connector cable using the iFixit opening tool.
    • Remove the camera from the motherboard.
Conclusie
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 33
Altijd: 239
