Ga door naar hoofdinhoud
ZTE Jasper LTE Screen Replacement
Wat je nodig hebt
  1. ZTE Jasper LTE Screen Replacement, Battery: stap 1, afbeelding 1 van 1
    • Insert the spudger into the bottom left corner of the phone.
    • Use the spudger to loosen the back cover.
  2. ZTE Jasper LTE Screen Replacement: stap 2, afbeelding 1 van 1
    • Insert the black spudger near the bottom left of the battery. There will be an opening to easily to remove the battery.
    • Continuing to use tool, prop up the battery and remove it.
  3. ZTE Jasper LTE Screen Replacement, Camera: stap 3, afbeelding 1 van 2 ZTE Jasper LTE Screen Replacement, Camera: stap 3, afbeelding 2 van 2
    • Remove nine 0.8mm Phillips #00 screws.
  4. ZTE Jasper LTE Screen Replacement: stap 4, afbeelding 1 van 2 ZTE Jasper LTE Screen Replacement: stap 4, afbeelding 2 van 2
    • Remove the back cover by pulling upwards.
    • Removing the back cover may take a bit of force.
  5. ZTE Jasper LTE Screen Replacement: stap 5, afbeelding 1 van 3 ZTE Jasper LTE Screen Replacement: stap 5, afbeelding 2 van 3 ZTE Jasper LTE Screen Replacement: stap 5, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Disconnect the gold component attached to the camera by pulling upwards using the tweezers.
    • Remove the camera using the tweezers by gripping tightly around the camera and pulling upwards.
    • Camera is attached to the motherboard with adhesive. As such, you may need to use light force to remove the camera.
  6. ZTE Jasper LTE Screen Replacement, Screen: stap 6, afbeelding 1 van 1
    • Disconnect all of these parts from the motherboard.
  7. ZTE Jasper LTE Screen Replacement: stap 7, afbeelding 1 van 3 ZTE Jasper LTE Screen Replacement: stap 7, afbeelding 2 van 3 ZTE Jasper LTE Screen Replacement: stap 7, afbeelding 3 van 3
    Koop
    • Remove the 0.8mm Phillips #00 screw from the bottom right.
    • Disconnect the gold pin by pulling upwards with the tweezers.
  8. ZTE Jasper LTE Screen Replacement: stap 8, afbeelding 1 van 3 ZTE Jasper LTE Screen Replacement: stap 8, afbeelding 2 van 3 ZTE Jasper LTE Screen Replacement: stap 8, afbeelding 3 van 3
    • Lightly disconnect the power button, volume button and the chip from the motherboard.
    • Be careful not to tear the volume and power button off the motherboard.
  9. ZTE Jasper LTE Screen Replacement: stap 9, afbeelding 1 van 2 ZTE Jasper LTE Screen Replacement: stap 9, afbeelding 2 van 2
    • Lightly move clip back to release the motherboard.
    • Gently pull the motherboard away from the screen.
Conclusie
Anthony Sou
391 Reputatie
4 handleidingen geschreven
UW Tacoma, Team S1-G1, Cardinal Spring 2019 Lid van UW Tacoma, Team S1-G1, Cardinal Spring 2019
UWT-CARDINAL-S19S1G1
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 258
