Ga door naar hoofdinhoud
ZTE Grand X Max Plus Motherboard Replacement
Wat je nodig hebt
  1. ZTE Grand X Max Plus Motherboard Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Make sure you turn off your phone before starting.
    • Heat the phone using a heating pad, heat gun, or hair dryer to loosen the glue. You just need to heat the back of the phone.
    • You can also use a hair dryer or a heating gun for this step.
  2. ZTE Grand X Max Plus Motherboard Replacement: stap 2, afbeelding 1 van 2 ZTE Grand X Max Plus Motherboard Replacement: stap 2, afbeelding 2 van 2
    • After the phone is heated, use the blue plastic opening tool on both sides of the phone.
    • Don't apply too much pressure because the cover can crack easily.
    • To avoid that your cover cracks, you can add tape to back cover.
    • You can use a suction cup to help remove the battery.
  3. ZTE Grand X Max Plus Motherboard Replacement: stap 3, afbeelding 1 van 2 ZTE Grand X Max Plus Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Carefully remove the cover from the phone.
  4. ZTE Grand X Max Plus Motherboard Replacement, Battery: stap 4, afbeelding 1 van 2 ZTE Grand X Max Plus Motherboard Replacement, Battery: stap 4, afbeelding 2 van 2
    • Use a plastic opening tool to pry the battery off.
    • The battery will be held down securely by glue, so it'll take quite a bit of sliding underneath to separate it from the compartment.
  5. ZTE Grand X Max Plus Motherboard Replacement: stap 5, afbeelding 1 van 3 ZTE Grand X Max Plus Motherboard Replacement: stap 5, afbeelding 2 van 3 ZTE Grand X Max Plus Motherboard Replacement: stap 5, afbeelding 3 van 3
    • Pull up the piece that is connected to the motherboard. You can pull it using your nails.
  6. ZTE Grand X Max Plus Motherboard Replacement: stap 6, afbeelding 1 van 2 ZTE Grand X Max Plus Motherboard Replacement: stap 6, afbeelding 2 van 2
    • Remove the battery.
  7. ZTE Grand X Max Plus Motherboard Replacement, Motherboard: stap 7, afbeelding 1 van 2 ZTE Grand X Max Plus Motherboard Replacement, Motherboard: stap 7, afbeelding 2 van 2
    • Use a screwdriver with a JIS #000 head to remove the (8) eight screws.
  8. ZTE Grand X Max Plus Motherboard Replacement: stap 8, afbeelding 1 van 2 ZTE Grand X Max Plus Motherboard Replacement: stap 8, afbeelding 2 van 2
    • Use a plastic opening tool to remove the plastic piece in the upper part of the phone.
  9. ZTE Grand X Max Plus Motherboard Replacement: stap 9, afbeelding 1 van 2 ZTE Grand X Max Plus Motherboard Replacement: stap 9, afbeelding 2 van 2
    • Use the same tool to pry off the plastic that is covering the motherboard.
  10. ZTE Grand X Max Plus Motherboard Replacement: stap 10, afbeelding 1 van 3 ZTE Grand X Max Plus Motherboard Replacement: stap 10, afbeelding 2 van 3 ZTE Grand X Max Plus Motherboard Replacement: stap 10, afbeelding 3 van 3
    • Repeat the same steps for the bottom part.
  11. ZTE Grand X Max Plus Motherboard Replacement: stap 11, afbeelding 1 van 2 ZTE Grand X Max Plus Motherboard Replacement: stap 11, afbeelding 2 van 2
    • With the same screwdriver, remove the two screws from the motherboard.
  12. ZTE Grand X Max Plus Motherboard Replacement: stap 12, afbeelding 1 van 3 ZTE Grand X Max Plus Motherboard Replacement: stap 12, afbeelding 2 van 3 ZTE Grand X Max Plus Motherboard Replacement: stap 12, afbeelding 3 van 3
    • There are three clips holding the motherboard.
    • Unclip the motherboard from the phone with the plastic opening tool.
  13. ZTE Grand X Max Plus Motherboard Replacement: stap 13, afbeelding 1 van 2 ZTE Grand X Max Plus Motherboard Replacement: stap 13, afbeelding 2 van 2
    • Remove the motherboard from the phone.
Conclusie
Jordano Baer
689 Reputatie
5 handleidingen geschreven
USF Tampa, Team S9-G4, Remmell Fall 2017 Lid van USF Tampa, Team S9-G4, Remmell Fall 2017
USFT-REMMELL-F17S9G4
4 Leden
10 handleidingen geschreven
Één opmerking
Hello I recently repaired the screen on this same device by changing th whole front screen assembly with its frame. Once I finished the repair the phone seemed to function normally but now the phone cant connect to any network and keeps on thinking its on airplane mode. What could this be related to?
Amador Sandoval - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 11
Altijd: 850
